Aluminum 454 Build
Filters on mine killed about 20 at the tire.....
And don't be bummed when it sounds like a little 383 at idle.
. Even with cat less duals on mine, I always get, "surprised it doesn't make more noise".Really hope it runs as good in the car as it did on the pump!
You can download the program for 30 days. There is a work around so you can print it or make a JPG.
Shoot me a PM if I can help.
ACDSee 3.1. It came with one of my older cameras and I have used it for years. If you can find the software and have any issues, let me know.
I can converter it to JPG for you if you want to email it over. I will send you my email.
My helper...
So that is the trans cooler, front brakes, gauge cluster, complete A/C system, complete car wiring harness, fuel tank straps, radiator install kit, and some other odds and ends...Next weekend will be a busy one filled with mostly wiring and plumbing after I get the engine and trans set back into place....definitely a bunch of stuff that needs to be installed and sorted out now...
