When are rod bolts needed? L92 shortblock
Old Jun 19, 2013 | 12:46 AM
93hatch's Avatar
Default When are rod bolts needed? L92 shortblock
fresh rebuild, zero miles, looking for 7-7500 shifts, what will be the first thing to break? Hoping for 650 crank, ported ls3's and a carb
Old Jun 19, 2013 | 07:22 AM
redtan's Avatar
Rod bolts and rods will be the very first thing to go at those RPM if the tune is good.
If the tune is bad (with knock and lean AFRs) look for the pistons to start failing first.
That is given that you have a stable valvetrain for those kind of RPMs.
Old Jun 19, 2013 | 10:05 AM
93hatch's Avatar
Valvetrain will be set, more worried about rpm limits on stock bolts
Old Jun 19, 2013 | 10:16 AM
redtan's Avatar
I'd for sure upgrade the rod bolts and maybe even the rods themselves.
By the time you buy ARP bolts and have the rods resized you are spending almost a much as a new forged rods with ARP bolts already there.
Old Jun 19, 2013 | 12:51 PM
Rise of the Phoenix's Avatar
Rod bolts are pretty cheap insurance at those RPM's.
Old Jun 19, 2013 | 02:05 PM
SNLPerformance's Avatar
Not sure how often it's going to see that rpm, but my GTO with ARP rod bolts has seen 7500 numerous times and 8k a few times with a carb intake on it.
Old Jun 19, 2013 | 07:04 PM
jimmer1g's Avatar
So at what RPM are rod bolts needed 6500, 7000, 7500?
Old Jun 19, 2013 | 07:09 PM
93hatch's Avatar
^that is my question. The car will be a 100% street car with the weekend races here and there
Old Jun 20, 2013 | 08:55 AM
redtan's Avatar
Rod bolts are cheap enough insurance that they should be replaced anytime you take it over the OEM rpm limit.
Old Jun 20, 2013 | 09:38 AM
jimmer1g's Avatar
Thank you for the reply one more question are the rod bolts just remove and replace or is there machining required
Old Jun 20, 2013 | 10:10 AM
redtan's Avatar
On stock rods you have to resize them...that's why I said in my previous post that by the time you buy the rod bolts and resize the rods, you are spending almost as much money as brand new forged rods with ARP rod bolts.
