found in first oil change after rebuild...
You may want to consider doing an upgrade to your rocker arms. Comp Cams has a trunion bearing upgrade kit. Summit Racing has one too. The Summit kit may be Comps with Summit name on it. The Summit kit is $99 and Summit also sells a tool kit to do the upgrade using your bench vice.
