tfs 255cc ls3 heads vs prc 260cc ls3 heads
GMPP CNC LS3 heads? Port size 279cc! very large!.......Also talked to Jason you will have to change rocker-arm pedestal to change over to TSP ls3 style heads from factory L92..I'm using T&D shaft mounted rockers..T&d stated that you could shimmy it....Also Jason stated that the as cast versions of the 255's will be out around next month for around 1500 bucks.
I went with the TFS 255's aswell but will be cnc'd by TEA. By the research I have donr, the TFS has a smaller intake and exhaust port then PRC and the MAST head and still outflows both of them. You also cant beat the reputation of a trickflow.
http://forums.corvetteforum.com/c5-t...s-382-cfm.html
Great thread on the heads. Got mine from Martin for 2590 with titanium rwtainers and PAC Springs. They also come with billet pedestals for ls3 rockers
