Garage Built LS7
What radiator are you going to use? Also, are you going to run an oil cooler? I'd highly recommend an oil cooler, I have a real nice Setrab out front of my radiator, and I've been running consistently 180-200 temps. This is with it still cool out, I'd imagine it'll heat up a little come spring and summer!
basically at the end of this im going to have a giant garage sale of parts im not using... including enough t56 parts to put together about 3 of them with varrious options... might have a little oxidation but nothing a lil cleaning cant fix... downsides to living on the beach... that and the humidity condensation is ruining my paint. it gets under the clear coat and bubbles up and flakes.
They are on a PCB with a common annode. I am hoping to be able to do some clever wiring and use them as indicator lights but putting them behind my gauge face and put 5 small holes in it foe the lights to come through. I will have to build a small board with resisters to significantly drove the input voltage with a bunch of resistors and i was think them i would attach them
1) 2nd fuel pump
2) transmission circulating pump
3) nitrous 1st stage
4) nitrous 2nd stage
5) oil cooler fan should i install one
this way i can quickly confirm that everything that is suppose to come on automatically actually did and shut it down if it didnt
Extra parts everywhere!
From what I've seen, been told, and read, on the LS7 the Fast doesn't gain any peak HP over the stock intake. You'll gain some on torque below the curve, but really torque will be the last of our concerns. Also, look at the dyno curves on the 116 and 110, compared to the K501. The 116 is out of gas at 66-6800, the 110- 64-6600. They're called torquer for a reason, they have low end grunt, but run out of steam up top. The K501 will pull to 7300 and honestly give you better driving characteristics down low IMO than the torquers will. For instance, my dad's Z can get flat out unruly on a 30 punch in 2nd. The butt comes out, and it's like you're riding on marbles. Where as, mine plants and goes! Power is linear, but comes online a freight train above 5! I don't blow the tires off it.
Also maroon and 427.. interested in the extra parts...name them all.. If u guys can shoot a pm lmk.. I interested in t56 parts as well
Btw I'm going be using vp 104 unleaded race fuel in mine.. thot about doing 13.1 cr and using the corn. But wasn't sure if wanted to pay for extra parts and buying bigger injectors. Running 60s now.. well going to be. Guess us 3 have very similar builds. Kinda cool to me lol
E85 would require more injector in the duty cycle is pretty high already. I'd imagine 60's would be ok as long as you're not laying a huge shot to it. Also, I need to sit down and get the parts organized in the next couple of weeks. Once I do, I'll let you let you know.
