Help identify this brand of valve spring kit
Could somebody help identify what brand/model/etc these retainers are? I am hoping that the previous owner purchased as a kit. I want to know the brand so that I can narrow down the springs spec. I am consider swapping out the cam and would be nice to know if these springs will be good for the next cam.
Please help if you can.
Thanks,
T
[URL=http://s20.photobucket.com/user/fuzzy_Tanit/media/FD3S/LS2-5/IMG_9317.jpg.html]
Springs will be hard to tell since multiple companies use the same damn springs and just repackage them with their name.
Take the cam number and call Lunati. I think that code LUN 55099 is generic for their custom cam cut grinds. If I have time I will check some of my receipts.
If it were mine, I would change them out as you don't know how many miles on them.
13112 114 isn't this the grind No. ? The 114 would be the LSA. I've never seen the grind no. placed behind the timing sprocket, but I guess it's possible
For regular street driving, I'd remove the springs and test each of them to make sure that their spring rate, open/closed seat pressures matched up with what Lunati recommends for their cam. If they're off or don't match up to Lunati's recommendation, dump 'em. (Springs are easily to replace than a drop valve.)
Hope this helps.
Spings, I am still at a lost.
The only thing I know is Push Rods are Comp Cam HiTech 7.325"
So it's basically up to me if I would like to change keep it or replace the entire set. DAM ME!
