Project YOLO: The Quest for 100 HP per Liter
You would think these dyno's would have straps for downward pressure if needed instead of loading up the back seat and trunk with heavy friends. lol. Maybe a full tank of gas and a little extra air pressure might net a few extra ponies. Hmmmmm. Be a good time to load the back with groceries as well.
Awesome build thread. Good luck today and hope the numbers are in line with expectations. Regardless of what the dyno says, it sounds like you have an awesome setup that should be a lot of fun at the track!
Alright! BTW, do you have a new ride yet?
Welp, she made 554/490. It needs more cam. We threw 30* of timing at it! and it still wouldn't detonate. I'll need more cylinder pressure from a bigger bump stick to take advantage of the extra flow from these heads! She's pulling hard to 7100, and making 550 for the full last 1k revs. Nice things are: it has 420+ft# of torque from 2500; and the HP is completely linear all the way up! It acts and drives like a stock C6Z with more HP everywhere.
I'll post the vid as soon as it loads in photobucket!
Yep, more cam! Kinda like more cow bell! We'll see if a switch is in order, although, it really drives nicely. Stock C6Z like, but w/ an extra 100 wheel or so.
either way its still one bad *** car!
