Project YOLO: The Quest for 100 HP per Liter
Thanks Knight , full vids will be done when it's finished, and shortly after, it'll be mile ready!
[QUOTE=427zm;17901506]I hope this isn't my mid-life crisis, I'm 33!
That is going to be a beast! Will you be running E85 on the street? That's some serious compression!
No ima be running ms 109. Iv heard to much problems with e85.. ur going need bigger injectors if running e85.. Ima be running 60s and unleaded race fuel. E85 gotta have bigger inj bc motor will lean out or not produce the power u want bc tune wnt be up and up
Moderator
Sounds like you should come close to your goals based on Doug's build in this thread since it looks like you're using the same cam https://ls1tech.com/forums/dynamomet...hp-532wtq.html.
Two pearls of wisdom that I would offer you.....go with a 0.040" thick head gasket for proper quench on pump gas (I use this gasket with 11.8 SCR and pump out 680RWHP on a stock LS7 short block using 92 octane pump gas!) and get the larger 102mm TB and use a ported FAST.....then you'll exceed your goals! Good luck, nice build!
What MPH should 600 wheel in a Vette produce?
#36
My ERL 434 is sitting in the garage waiting to be assembled, sad to look at. I plan to run the WCCH stage 2's with 0.040 gasket for SCR 11.8 and i have a katech torquer 116 which should put my DCR around 9.0. Where are you gonna get it tuned?
#39
The Cometic is the stock thickness, .051. This is what QMS recommend I use. Since they probably have messed w/ more LS7's than just about anyone else in the country, I'm taking their advice.
#40
I have it already. It is kind of close on the DCR, but the 110 version with factory compression puts it at 9.1:1 DCR and people run that on 91 octane. I was considering running the 0.051 gasket since i already have it, but after reading, pretty much everywhere recommends running 0.040-0.045 quench for better performance and motor longevity on the street. Not entirely sure how it does this though
