LS1 Rebuild to 500-600HP
#63
An LS3 does not use a 383 rotating assembly. The crank is the same but with a different reluctor but the pistons are quite a bit bigger. Stock size is 4.065" I think.
With a rotating assembly from TSP you get a 4.070" or 4.080" piston making it a 416ci motor. With a stock piston you get 414ci.
#64
#66
Ok. I might get a LS1 from the junkyard just to be able to work the build and still be able to drive the car. It's a thought.
#67
Hmm... maybe I can start with just the LS1/LS6 block...
http://www.summitracing.com/parts/na...make/chevrolet
#68
What about running an LS2 block with LS3/L92 heads setup? You should be able to hit your numbers and stay under budget no problem and this way you get to use the LS3 heads.
#70
Was never put on the dyno, but good for 12sec@118mph with a crappy 0-60, street tires full weight,, 3:42 gear and couldnt shift the trans at high rpm. Around 460rwhp I'd say.
#71
Great idea and cheap with the LS3 intake/heads/fuel rails/injector. Thats what I had and it was a killer combo. I had a 230-236 cam with 11.1:1 CR ported LS3 heads. Stock LS2 block.
