TSP VVT-4 Phaser Table
Does anyone have the phaser table for a VVT4 cam. Bought the cam package a while back from texas speed and the phaser tables werent in the box or I lost them. We were going to try to tune it today. Any help would be greatly appreciated.
I find it kinda funny. TSP made a point when they first came out with their line of VVT cams that they were the only VVT cam supplier that supplied the customer with the phaser table. :headshake:
IIRC………… TSP said they weren't going to dropship these cams. SO there's NO reason they shouldn't be sending the tables with the cams. They are dropping the ball.(again)
Interesting that VVT3 and VVT4 are the same.
Can you please email all the tables to my email?
Curious what the other tables look like.
What are the cam specs for the VVT4?
Thanks,
Mike
Wasn't 100% sure the VVT3 table was the same as the VVT4 table. Was going to offer the table to you also.
Thanks,
Mike
Thanks,
Mike
I'm not sure if anyone else with the vvt-x cams noticed but they come with the 5456 Cam Phaser kit which is for the 07-08 engines with the 12585994 phaser. The 12606358 phaser in the L99 should be using the 5460 Phaser kit. When I queried TSP I was told that the older Phaser kit limited the timing more so that is why they are using it.
Just got another response from Comp Cams on the Phaser kit. "Hello James, I did some digging. Looks like Texas Speed is correct. The 5456 will work either way. The 5456 limits the phaser to 16 degrees of movement, where the 5460 will allow 22 degrees of movement. I really don't think there is going to be a big power difference."
To address the phaser limiter, all of our cams are designed around the 5456 Comp phaser regardless of year of the vehicle. It made it much easier when designing our camshafts to make everything equal and allow us the best margin of err to ensure no PTV clearance issues.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
