"Cathedral" or Rectangular" Cylinder Heads ?
Piston rock is a factor in any stroke over 4", from what I've read online.
"Shorter Deck Height issues of the past" ? Don't all of the production LS motors have a 9.240" Deck Height ? I'm worried about Compression Height issues, oil consumption, and longevity, even with a 4" Stroke.
The rod "issue" is a question of strength vs. weight (I-Beams are usually lighter ).
LY6 - I have considered that, but the static compression is only 9.67:1 and I would be getting a cast rotating assembly. It also retains the stock 3.622" stroke.
I averaged 17 in town and 24 on the highway. Beauty of a 6 speed. If I would of actually put heads on it, swapped pistons it would of been much more efficient fuel economy wise and made more power (obviously) LOL. Of course that all changes with the long skinny pedal.
I did build a 4" stroke LS3 based engine to replace it though, since you brought up LS3's.
Yes production LS motors come with 9.240 deck height but its different from the deck height of small block chevy's, etc where piston rock oiling issues were a problem.
I suppose I shouldn't of worded it like piston rock doesn't exist, my fault. I was tired. LOL. Its more or less, I wouldn't really worry about the oil consumption portion of it.
Rods
Yes I-Beams are lighter.But I don't personally (just my opinion) think the weight savings would be noticeable for this. I'd save my money and just go with the H-beams from Callies or K1. The rods usually weigh right around 615-650g depending on manufacturer. If you go up in rod selection to more pricey items, they are all almost usually I beam.
LY6
Yeah you would get the cast rotating assembly, but if you compare how much you would spend for a set of LS3 heads, and then the block it adds up. Unless your peeling apart a donor motor for covers and sensors for your build, you'll have to buy all those again too. But pull-out motors have all this already. You want to build a stroker anyway, so sell the stock internals (crank is worth some $), refurbish the heads. Forge it how you like, add a cam, timing chain, swap oil pans, space windage tray, etc.
I would totally understand you wanting to buy new heads and a new block. Nothing wrong with that. Just thought I'd throw that out there so you wouldn't have to source parts from different people, pay multiple shipping costs, etc. Usually cost $100-120 to ship a block, $50-60 for heads. Or $200-250 for an entire engine LOL. You'd also have an extra accessory drive, wire harness, etc to sell of for some extra cash if you wanted as well.
OR buy cheapo LQ4, sell off the whole top end and internals, save the block, covers, and misc items, forge it, and add heads/intake as you like! Be a cheaper starting option.
Martin chimed in on his build, he specs some really nice cams. Quite similar to what your doing. But I don't think that build is worried about being a sleeper.
No, with 7000 Rpm and 6600-6700 rpm shift points, we are definitely not talking about a "sleeper" - LOL ! Sounds like he would have to run a 3500-4000 rpm stall converter, too. That doesn't sound like a "recipe for mpg" or "street manners" to me.
All you have to do is tell Martin what you want, and he'll hook you up with a good cam.
As for heads, the "standard", non-CNC ported, L92 heads should have sufficient flow. With the larger ports of the CNC'd L92 heads, I'd be worried about low velocity and sluggish response at low rpm.
https://ls1tech.com/forums/pontiac-f...418-build.html
Here is another LS3 stroker but with CNC 243s https://ls1tech.com/forums/dynamomet...r-1x3-4-a.html
Unfortunately, that thread has me thinking again . . . LOL !
The goal is a full-weight, daily-driven, street car capable of mid to high 11's ( no faster than 11.50 - no Roll Bar ) with a QUIET,closed exhaust system, just by bolting on a set of drag radials, when headed for the strip. Otherwise, on a daily basis, the car appears and "sounds" like a "stocker". I am looking at the quietest mufflers and exhaust system I can find.
After a lot of soul-searching, I'm either looking at the 408 LQ9 Short Block (all-forged ) from Texas Speed ( I'll put L92 heads on it ) or an LS3 crate motor ( cam swap ) . . .
Who has the best prices on LS3 Crate Motors ?
Thanks !
Not to mention we are giving the hollow stem upgrade free on the 260s right now!!
http://www.texas-speed.com/p-4010-pr...der-heads.aspx
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Jason,
Don't the 6-Bolt heads only fit the LSX block and not the "production" 4-Bolt blocks ?
These parts and the L92 heads are all new ?
https://sdparts.com/details/scoggin-...er/x88958765-2
OR
L92/ LS3 CNC-ported heads for $695 per head
https://sdparts.com/details/scoggin-...enter/sd5879-1
That SURE sounds better than dropping $2300 - $2700, or more, on aftermarket heads, in terms of "bang for the buck", for my application !
There is more mechanical noise from the engine than there is from the exhaust.
It is quite a deceptive sleeper having run all it's times on the factory 18" wheels with drag radials.
