building a 5.3
I have made a thread similar to this in the past but some new questions have come to mind. I am building an L33 to put in a 350z. I planned to keep it NA but after some research and input from others it seems that I will not reach my power goals with an NA 5.3. I want to reach at least 400rwhp or more. not flywheel hp... who counts flywheel Hp anyway? So I've done a little looking into turboing the 5.3 to make some power But I don't want reliability issues and won't have the money to fully build an engine and build a turbo kit. So which do you all recommend? Build for NA or turbo on low psi and do minimal upgrades to the engine to handle the boost?
Thanks
350-375 at the wheels, and the torque that'll come with it, is going to be a LOT more fun than the stock VQ. add the 75-100 shot for when you want more fun.
Thanks
If you were to build it for 400whp without a power adder, it would be very simple to bore and hone the block to 3.898" and use a stock LS1 rotating assembly. Then you really just need the basic bolt ons and a cam swap to hit 400whp.
Either plan would be similar in cost, I would think.
not sure if you've seen this oldie but goodie, but it's a good base from which to start.
http://www.carcraft.com/techarticles...e/viewall.html
I have seen this article. All the power they make is on an engine Dyno. But it does look good. If I where Building my L33 for NA power I was looking to get TSP Cam Upgrade Kit 228r 112lsa not sure if I want dual valve springs or single? Also comes with chromoly Push Rods And I Would Get Ls7 lifters and arp rod bolts. Mill the head down for some extra compression And Possibly Run e85. If I where boosting it, I would only do rod bolts head studs and add a turbo kit. So I'm having trouble deciding. Turbo means more power but more cost with tuning and of course the kit it self. I not sure which is the better for me.
Get the heads ported and milled, a nice cam with a FAST intake and you should easily reach 400 with all other bolt ons (udp, headers, cai etc). Just make sure to get good compression and to go with a well matched cam.
As for E85, make sure you update your fuel system to handle it. The ethanol runs a higher risk of corroding things quicker, and the Z wasn't intended to be run on E85. Plenty of guys on the Z boards had issues with seals and pipes deteriorating within a few months of starting to use it without replacing/updating with appropriate kit.
