Solid cam LS3
My whole purpose for making noise on the OPs thread was to warn him of the extra labor and possible pitfalls of running solid rollers on the street, especially with the RPMs a hydr roller can spin to these days.
Someone educate me on how the LS engines can run the solids without issue compared to the other engines in the GM stable. Im always happy to learn something new. I think its a waste of time to get out of bed in the morning if you don't.
I dyno'd at 440rwhp and ran 124mph with 4100lb.
Looks like Cam motion has a neat low lash solid roller in trial atm?
I don't mind either or hydro or solid, i take it the maintenance will be similar, just want what's most reliable at the upper end of the rev range for a stock bottom end ls3.
If 5206 morels will reliably do it then I'll use them, but if a solid will gain more power and won't have many drawbacks as kip from cam notion has stated from his. Then what's to lose?
