Add Port to 4" Silicone Intake Tube?
Old 04-04-2014 | 04:49 PM
TEDSgrad's Avatar
Default Add Port to 4" Silicone Intake Tube?
I have Saikou Dual Catch Cans. I need a fresh air port between the throttle blade and the MAF. Since I have a stock LS2, the DBW TB has no provision.
What is a good quality fabrication for installing a port in the silicone?
Here's the Saikou simple diagram. The LS2 Vettes have the plastic air bridge, but I have the silicone. Also, here's a look at someone's attempt.
I'm concerned about obstruction inside the tube, and air tight. Any thoughts, ideas?
Attached Thumbnails Add Port to 4" Silicone Intake Tube?-diagramcatchcans.jpg   Add Port to 4" Silicone Intake Tube?-nipple-tube.jpg
Old 04-04-2014 | 04:57 PM
John B's Avatar
Moderator
Just poke a hole (drill it!) and insert a threaded nipple!
Old 04-04-2014 | 05:04 PM
TEDSgrad's Avatar
I'm having a hard time visualizing that. Do you have a pic?
Old 04-04-2014 | 05:57 PM
John B's Avatar
Moderator
It's a little hard to see (circled in red the fitting is pointed downward) but I drilled a hole into my rubber hump tube (between the metal clamps).
Old 04-05-2014 | 12:05 PM
TEDSgrad's Avatar
Found what I was looking for. Will probably grind the flange down a little just to reduce obstruction as much as possible inside the silicone tube. It's made of aluminum, threaded on the outside so it will fit snug, and has the 3/8" hose barb.
Old 04-05-2014 | 07:58 PM
99Bluz28's Avatar
Those are nice, should be perfect for what you need!
BTW, where did you find them ?
Old 04-05-2014 | 08:43 PM
TEDSgrad's Avatar
Available in straight, 45*, and 90*
http://www.ebay.com/usr/thrasherprod...p2047675.l2559
Old 04-11-2014 | 12:43 PM
TEDSgrad's Avatar
Got the piece. Ground the flange head down to 3/16" (there's a rubber washer in the pics). I could go more, but I'm not an air flow engineer.
Once I get the silicone tube hole drilled, I'll use 3M weatherstripping around it.
Attached Thumbnails Add Port to 4" Silicone Intake Tube?-dsc00702.jpg   Add Port to 4" Silicone Intake Tube?-dsc00703.jpg
Old 04-11-2014 | 02:06 PM
99Bluz28's Avatar
Just make sure to make the Hole only as big as it need to be. IMO, I would probably remove the rubber washer and just use a bead of RTV sealant around the base of the barbed tube, then another bead around the tube where it protrudes through the silicone tube, before threading the nut on.
The following users liked this post:
67_ls1 (11-22-2021)
Old 04-17-2014 | 08:00 PM
TEDSgrad's Avatar
Works well with no problems. The hose is not as taught as it looks in the pic.
Attached Thumbnails Add Port to 4" Silicone Intake Tube?-dsc00704.jpg   Add Port to 4" Silicone Intake Tube?-dsc00705.jpg   Add Port to 4" Silicone Intake Tube?-dsc00706.jpg
Quick Reply: Add Port to 4" Silicone Intake Tube?
