Beehive or Dual Valve Springs!!!
Hey all!!! So I decided on the cam Iʻm going to get for my 5.3 Tahoe (214/224 .500/.500 115lsa)... So now I am deciding on which springs to get with them? Do I go with the Beehive or Dual Springs??? Iʻm thinking the dual will give me more strength but I want to know what you all think???
Thanks in advance!!!
A small cam like that would be better off set up with a beehive spring. In this application a dual spring is not nessasary. Find a set of psi 1511ml or even the comp 918 should do the job just fine here. PAC makes some beehives that would also work well here. I had the PSI springs on a eps 226-230 .598 .600 cam for 3 years and about 30k miles and their still fine.
Here are some high quality springs that we're using on our .550" lift truck cams.
http://www.briantooleyracing.com/560...-12565313.html
