Next project - 402 or 418 stroker - piston question
LQ9 stroker with Frankenstien LS3 heads & a solid roller was Dirt cheap well under 7000 grand and I bought every part, also... I will not take Anything less than 700fwhp under 7500rpm or this was just a USE-LESS BUILD.
Any how, I'm currently at 580 wheel NA and 700 on a 100 shot. There's a few more additions that have to be made, like a fast 102 and tighter headers as 2" headers are just too much for an NA motor. It runs like a scolded dog and can be beat on until the cows come home.
Jake, my apologies if this mucked up your thread buddy. Personally, now having both cathedral ports and rectangular ports, I can tell you the endless power band of the rectangular port is straight intoxicating! They never seem to run out of air!
Btw, I can't seem to find shelf pistons for the 4.07" bore that give me what I want from Wiseco or Diamond and spending the extra for custom is not exactly in line with my overall goals... So 402 it looks like or maybe a 408 if I can stomach the iron block weight. The good thing from the 408 is I reuse my ARP head bolts, Rollmaster timing set, and my new LS6 valley cover I installed. Those things, individually, are not that expensive, but when you buy multiple parts over and over again... well it gets stupid.
Given the 226cc ports and 2.04" valve (think I'll just keep those so I can add more duration/overlap) the flat tops with the chambers opened to 66cc will net me around 12.1:1 CR with .035" quench. An EPS 248/254 113+3 would work well in that setup and make power everywhere given the smaller ports and valve size relative to the bore.
Now I will be spending on build & dyno time... LME = Total is right around 9 grand close to 10 complete. 427 you have a great set- up but, not 4 a Baller on a Budget.
also 510 is damn good... a guy whos home we were doing friend in League City, had a E85 Black 427 ZO6 with H/C/I work done... Beast.
I did a post on the new JE piston look it up. My pistons from JE will cost 895 but I lost some on the restock fee from Wiseco... I could send them back because It was not a custom piston.
Yes, mine is a 414ci build making 560/535 on a hot humid day.... I too am going to spray it w a 150 shot soon...
Callies Compstar, 4.125 crank, TEA worked 799's... Ported FAST 102, HS 1.8's.. It's a fun fun car... and still gets 24-25mpg on the hwy in 6th gear w the Ac blaring...
