Head Suggestions for Lightweight LS2 402ci Stroker
Old Jul 13, 2014 | 10:55 AM
lil john's Avatar
If you got it.. let it hang
or as Katt Williiams would say: Working with monster..
Every1 has a goal. GM makes it EASY 2 get what ever your goal is...with FACTORY parts. So the aftermarket would be overkill and not budget friendly...
Old Jul 13, 2014 | 11:17 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Sent an email to Ed. I'm thinking of nixing the stock ported LS3 head. I just don't see throttle tip-in being there like it is with a cathedral.
I'm thinking at this point the small bore LS3's with the 240cc runner would be the ticket if I went with square ports. But they'd have to be optimized for a 4" bore. THOSE I could see still having some grunt in the low end and keeping up up top.
TFS 235's, or Chris Franks custom CNC'd TFS for Cathedral.
AFR's I'm thinking of steering clear of simply bc of the valve angle. I think I got lucky with my 205's @ 59cc with the HellRaiser cam (229/236 .631.631 112+2)
Old Jul 13, 2014 | 12:38 PM
Always2Slow's Avatar
Rectangle ported heads have a superior advantage in the short turn. I would do a small bore ls7 head if you are starting from scratch. I am sure you could find a used set of small bore ls7 heads at a reasonable price. As suggested earlier your cheapest power will come from ported l92 heads. The biggest problem with these heads is its much harder to get the compression you need out of them, but with a custom set of pistons should be very easy to do.
Old Jul 13, 2014 | 01:24 PM
dr_whigham's Avatar
The Scammer Hammer
ETP (gone), RPM, and RHS are the only companies that come to mind that ever did a SB LS7...? Is that right?
The RHS look promising, but the exhaust valve is a 1.575... Seems small to me, but I do have 1 7/8 Tri Y headers... Wonder how that works into the equation. But they're 266cc
Old Jul 13, 2014 | 01:43 PM
lil john's Avatar
The bare RHS LS7 small bore is dirt cheap... without the Cnc..
Old Jul 13, 2014 | 01:58 PM
dr_whigham's Avatar
The Scammer Hammer
Ha! Just emailed Dr J about some small bore LS7's...
http://www.j-performance.com/index.p...ask=view&id=52
As for the RHS, the cheapest I could find was around 1200 each
The 54503's
Still don't know what the valve angle is on either head.
Old Jul 13, 2014 | 03:02 PM
KCS's Avatar
KCS
Moderator
The 54503's
You can get the Pro Port for less than $600ea, but they'll need some port work, valvejob, and valvetrain. Since they're a raised runner head, you would need spacers for the intake manifold as well, which I haven't been able to find a part number for yet. I've been considering them myself.
Old Jul 13, 2014 | 03:12 PM
JakeFusion's Avatar
Super Hulk Smash
The TEA TFS LS3s do look good... but the intake manifold... eh.
For a 402, I still think Cathedral port can do the job. Once you move to a 4.125" bore I'd bypass the LS3s and go straight to LS7. The LS3s are beastly head/cam but I've never seen them put away a cathedral port head once you throw stroke and bore at a cathedral port head. You can overcam the cathedral port stuff to make up for any advantage of the LS3.
The Chris Frank TFS heads, ported FAST 102, and a 402 would be 550rwhp all day with a 248/254 type of cam. Add more compression and some tricks on setting up the valve train and I think 575-580 would be possible.
Old Jul 13, 2014 | 03:37 PM
lil john's Avatar
Did you all read that Frankenstien yellow bullet post about the 408 Hyd roller with a FAST intake... 697 hp with stage1 LS3 heads. Try that with the Cathedral port without some crazy cam & compression..
How much RWHP would 690fwhp add up to?
Old Jul 13, 2014 | 05:06 PM
dr_whigham's Avatar
The Scammer Hammer
I also did send Chris an email on Friday so I'll wait to hear back from him and what he has to say.
I think for myself at this point, I'd like to run a small bore LS7, if for nothing more than to just keep the theme with the LS7 internals and all. But then again that's me... thinking. I'll wait to hear back from Dr J's, Frankenstein, and Ed.
Even thought about cheating a bit with a short travel lifter and a solid roller cam, but I'm unsure if the polymer intake would even support it.
Old Jul 13, 2014 | 05:32 PM
(SS)'s Avatar
Keeping a eye on this.I'm interested in your selection and outcome.
Old Jul 13, 2014 | 07:10 PM
  #32
JakeFusion's Avatar
Super Hulk Smash
Probably in the 580-590 range depending on the driveline. Point is, he has cathedral ports with 600rwhp too. So meh.
Old Jul 13, 2014 | 07:30 PM
  #33
redtan's Avatar
Yeah somehow I don't see OEM castings hitting 600rwhp regardless who worked them unless running some crazy compression and RPMs.
Old Jul 13, 2014 | 07:45 PM
  #34
lil john's Avatar
Redtan remember I got the Vic Jr. intake and a solid roller.. I am sure that i will put up more than the 408 hyd. roller with these heads..
I got the same basic set-up as the 757hp @ 7500rpm 414ls with stage 2 heads ... I got the stage1 heads
his cam was 257/268 dur. & .730 something lift with a Compression ratio of I think 11.5
While my cam checks in @ 256/270dur. & 757 lift
think 600rwhp is that far away now with factory heads.
Old Jul 14, 2014 | 07:56 AM
  #35
dr_whigham's Avatar
The Scammer Hammer
I wish I could find a nice used set of Ti intake valves to get turned down...
Old Jul 14, 2014 | 08:08 AM
  #36
lil john's Avatar
How much are they.. I need some valves also..I know the valve spring package for my set-up...I haven't look @ a valve price in A long time.
Old Jul 14, 2014 | 12:26 PM
  #37
dr_whigham's Avatar
The Scammer Hammer
At least 800 bucks.
Good news. Received an email from Chris today and we've been trading back and forth.
I'm going with his heads, definitely.
After talking, this is what he came up with, and I'm fully on board.
Chris Frank of Frankenstein Racing Heads - "On the 4.0 bore we would use a 2.100-2.125 intake valve and a 1.59-1.60 exhaust valve. The intake port will be around 245cc-250cc. The valve angle will be 12* with a 60cc chamber or smaller. It will be a RHS casting for sure with some BTR springs."
Old Jul 14, 2014 | 12:31 PM
  #38
KCS's Avatar
KCS
Moderator
At least 800 bucks.
Nice. Be sure to get lots of pictures
Old Jul 14, 2014 | 02:25 PM
  #39
lil john's Avatar
Good deal.... 4 Cnc & shipping was 1200.oo for these
The work done was worth it... I got the page 4 your heads done by Chris..
Pro Elite LS7 raised runner casting.... on yellow bullet forums...
Old Jul 14, 2014 | 02:48 PM
  #40
427zm's Avatar
I agree with much if this, but I would also look at the small bore PRC LS7's. After seeing what Diet coke did with those heads out of the box, I sure look twice especially for the price.
The intake will be a bottle neck with an LS7 head. In our cars we don't have many choices, especially for the LS7 heads. They need air, a lot of air at that.
At least 800 bucks.
Ok, if you're going to use Chris, use his cam choice as well. Before asking me why look at my sig. He's good for the package together and he'll run on his own proprietary lobes. Truthfully the wisest decision.
