Head Suggestions for Lightweight LS2 402ci Stroker
Old Jul 12, 2014 | 01:31 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Default Head Suggestions for Lightweight LS2 402ci Stroker
Okay. Here's my dilemma:
Putting a deposit down on a 402 shortblock.
It will consist ofan LS2 block, a machined down LS7 crank, LS7 titanium rods, and some custom lightweight pistons from JE.
The thing about the pistons is the valve reliefs have to match the valve angle of the head, so we technically have 3 choices here, maybe 4.
Stock 15* that would be CNC'd and worked by either Chris Frank @ Frankenstein or Darin Morgan @ Rehr Morrison. I have no flow #'s for either, but know they'll be top notch.
Trickflow 12* 255's 2.165 intake valve & 1.6 exhaust
FLOW DATA 4.060" BORE
Lift Intake Exhaust
0.100 71 59
0.200 140 117
0.300 225 168
0.400 288 213
0.500 331 236
0.550 348 241
0.600 361 247
0.700 373 254
* Tests conducted on a Superflow SF600 at 28" of water, 4.060" bore, 1.875" exh. pipe
Mast 11* 256's 2.165 intake valve & 1.6 exhaust
Flow Data w/4.000" Bore Plate
Lift Intake Exhaust
0.100 74 61
0.200 146 119
0.300 222 188
0.400 282 219
0.500 330 236
0.600 360 251
0.700 372 260
I sincerely welcome any thoughts and opinions. If I can fit it under a cowl hood, which I haven't figured out yet, they might be paired with a Holley mid rise or hi rise intake.
Car is a 2004 Corvette, M6 with Phadt 1 7/8" x 2.1" x 3" Tri Y Headers, No Cats, and a Corsa Sport (catback stays for the time being, might custom fab a true 3" corsa from a C6Z)
I believe the real limiting factor here will be if I go with a polymer intake or a cast type...
Old Jul 12, 2014 | 01:49 PM
74u's Avatar
74u
Not sure on the heads, but you could crush beer cans and put it under the hood for additional spacing
Old Jul 12, 2014 | 01:51 PM
dr_whigham's Avatar
The Scammer Hammer
And Lord knows there's no shortage of said aluminum at my house...
Old Jul 12, 2014 | 04:48 PM
lil john's Avatar
I have both FLOW CHARTS and know both.. Just got FRANKS stage1 LS3 heads in today.. Sorry about drinkin and typin.. Work + i installed my own 4 ton A/c unit.. never went 2 sleep after i finished around 12 last night... I also got the TFS ls3 heads ...
Old Jul 12, 2014 | 05:01 PM
lil john's Avatar
So what do you want help with?
Old Jul 12, 2014 | 05:04 PM
lil john's Avatar
I don't get online 2 lie..
still rollin.. stay thristy My Friends..
Old Jul 12, 2014 | 05:37 PM
dr_whigham's Avatar
The Scammer Hammer
I'm looking for "suggestions" and experienced opinions, not necessarily help.
Who's experienced either of the heads, what manifold they were running, and how the power was.
Flow #'s don't necessarily mean ****, but you need to have an idea of what it's doing so you can pick a cam.
So John, care to post said chart?
Old Jul 12, 2014 | 11:57 PM
lil john's Avatar
U R better than 500fwhp...lol
Old Jul 13, 2014 | 12:10 AM
lil john's Avatar
I do this cause i love ..this.....but take this ...I....I built and bought this and I will say this. nothing came 2 gether...DRO time...I got 700fwhp on a bad day 4 less than .....U ...how about you take a bet...
I NO WHAT I NO
Dr. I am also a Surgical Tech...
So we back 2 WHAT U WANNA SPEND ... A suggestion is your Budget...
I LUV U 2
Old Jul 13, 2014 | 12:20 AM
LPE 403's Avatar
I NO WHAT I NO
I LUV U 2
Holy Christ, your posts are painful.....
Old Jul 13, 2014 | 12:32 AM
lil john's Avatar
Name a # LS/BBC/SBC/BBF/SBF/....etc .....I may no something or have Spent on this B 4
We run FORZA 4 U THINK IT CAN'T HAPPEN IN REAL life... Check my resume... No Lies..
Old Jul 13, 2014 | 12:52 AM
lil john's Avatar
& I will say this ......who is asking ??????
Y ask if don't want the answer.... FACT .. still rollin .
Look @ the avatar .... HULK is dead & ole spidey....
Any 1 can lose @ the track....
I like #s so U can try 2 figure out how 2 make it hook... My 700 fwhp IS NOT 4 DRAG ... just a g-body with hp & A/c ...
Old Jul 13, 2014 | 03:48 AM
lil john's Avatar
Hell i just started posting.....I am @ a REAL WORLD 600RWHP on the 1st TRY.
CHEAP....
Old Jul 13, 2014 | 04:16 AM
lil john's Avatar
Sorry took it THE WRONG WAY ..look this up ...A few LS1TECH people spoke...
Frankenstein's NEWLY designed LS3 heads .. on Yellow bullet .....
D @ Reher heads say that 368 cfm @ .750 with a 264 cc port .....I got the #s
Sorry again...
XXX.
Old Jul 13, 2014 | 04:34 AM
lil john's Avatar
Oh yeah this is 4 free...
Think about how much I wanted a Baby NASCAR SMALL block with A/c = 2. YRS OF RESEARCH...
Old Jul 13, 2014 | 05:34 AM
dr_whigham's Avatar
The Scammer Hammer
John, I appreciate the enthusiasm, and well, whatever else you're putting in here. I'm not quite sure what Forza 4 and surgical tech has to do with anything, but we'll just go with it for the time being. I will probably go back and edit some of your posts though.
I can honestly say if the car doesn't hit 540 I'll prob rip the motor right out and sell it.
I'm put max budget "around" 3k so AllPro isn't even in the question.
And I'll be honest, I'm not completely sold on a square port head. But I do wonder what the Mast "small bore" would do if the chamber were opened up for a 4.005" bore. 240cc would seem to me to give better port speed with a slightly smaller CSA.
No AFR's though. I want better than a 15* valve, but I'm curious to know what you put down, PaperMushrooms.
The cam will come from Ed Curtis.
Old Jul 13, 2014 | 09:58 AM
lil john's Avatar
Sorry I party hard & Work even harder...... ARMY thing ...
Did you find the info 4 the flow chart on Yellow bullet.... LS3 bare heads U 2 cost 175... in 08... hell of a mark up... glad I got'em bac then.
The stage 1 get 388cfm
Stage 2 401 cfm
stage3 410 cfm.. 4 Franks heads... I liked that the stage 2 heads got 757hp with a solid roller set-up that was Very close 2 my set-up... I went with the stage1 heads as this is a STREET car...I know that I still got 700 just with some low - mid range TQ...
Old Jul 13, 2014 | 10:04 AM
lil john's Avatar
And the Mast... TFS ... will make more power .... But @ a cost...think about it...the Hot Rod 408 head test gave you the REAL diff. in heads & Hp.
Base LS3 heads are hard 2 beat for what they cost...I am looking Good with them...700 horses strong.
Old Jul 13, 2014 | 10:05 AM
Blackpanther99's Avatar
Dafuk...
Old Jul 13, 2014 | 10:09 AM
TFS 225s or the AFR 225s will make GREAT power with that 402. Custom grind camand those heads will be insane.
