Help! Not sure which heads to run due to compression!
All I'm saying is that while you're at it you might as well beef up the bottom end. Sooner or later (more sooner than later) it's going to pop and you're going to have to take it out again and forge it. Why not do it now?
And if you're going to be opening up the motor for upgrades you definitely should do the rods too. For the price of ARP bolts and re-sizing labor you could've gotten forged steel rods with ARP bolts already there. But that's too late by now, maybe you can get some money back selling those and going with a basic h-beam rod for $500 and some wiseco pistons for $700. Along with balancing that $1500 is going to go a long way in holding your engine together at 20psi. Something that is pure hit/miss with stock parts.
If you plan on keeping this car a while and having fun, definitely spend a little money now to build it right. If you're only going to run it sparingly and will be unloading it soon then keep the engine stock and pray it holds for as long as you have the car.
