post your LS3 stroker builds please
Old Aug 5, 2014 | 04:09 PM
  #41
v8pwr's Avatar
TEA used to be owned by Brian Tooley so I think he gets the heads from there, just a hunch. I'm trying to finish my combo and I'm hoping within a month but we'll see. I have no time but I'm grateful for the reason.
416 11.5:1
ETP 245 w/ PAC-1530s
FAST 102 (My Limitation, going in C5)
Jesel J2K Mohawks & Jesel LS1 Dogbone Lifters
FTI Tight Lash Solid Roller Cam seen here https://ls1tech.com/forums/generatio...haft-****.html
Just got Trend 7/16-3/8 Double Taper .125 wall pushrods w/ 210 tip so I can finish the longblock.
Old Aug 12, 2014 | 08:35 PM
  #42
BOLO's Avatar
You're absolutely correct, Brian Tooley started Total Engine Airflow back in the early 90's. And he still uses TEA's CNC porting. I can't wait to get mine.
Old Aug 13, 2014 | 07:26 PM
  #43
93v8clone's Avatar
ill add to this , car is a 94 z and im currently building a ls3 based 427 with a 13-1 comp ratio , heads are livernois stg 3 l92 heads , cam is a tooley custom grind with a .623 intake lift 301 duration , exh is .596 lift and 319 duration on a 112 lsa . intake mani is a fast 102 n/w 102 with a nitrous outlet money maker kit inside set up for a 300 shot . trans th400 on a brake rmvb , edge 4500 stall , 9 in rear diff with a 3.90 gear .
Old Aug 22, 2014 | 10:12 AM
  #44
Coonass350's Avatar
That sounds like a solid setup!
Old Aug 22, 2014 | 11:44 AM
  #45
Rise of the Phoenix's Avatar
+1 on that. Money maker kit for the sleeper status. I bet it wins you more money than it costs you.
Old Aug 28, 2014 | 10:28 AM
  #46
4U2BNVS's Avatar
I'm building a 416 for my AWD TBSS. Here is some of the combo.
10.75 to 1 compression
WCCH stage 3 LS3 heads
LS9 Head gaskets and ARP head studs
Holley Hi Ram Intake with 102mm throttle body
ARH 1 7/8 Headers with custom 3" stainless true duals
CHI rockers 1.7
Katech billet doweled main caps
Oh and I almost forgot the biggest part
F1D Procharger
Old Aug 28, 2014 | 12:27 PM
  #47
Spectre86's Avatar
AES 427 stroker 11.75:1
AES custom cam
SDPC CNC'd ls3 heads.
Fast 102/100
560rwhp/500rwtq.
Old Aug 28, 2014 | 11:04 PM
  #48
trevmust's Avatar
I'm looking into this combo so far,
LS3 block
4.070 Wiseco pistons
4.00" Eagle crank
6.125" Eagle rods
Lingenfelter CNC'd heads,
Lingenfelter GT21 cam
stock manifold assembly,
Don't want to upgrade it too much, cuz im supercharging it later, but building it to have fun with it/break it in before I do that. I'm still trying to decide on the rest of the engine parts, suggestions more than welcome! (e-force supercharger btw with a custom tune)
Old Aug 29, 2014 | 01:13 AM
  #49
ducatisl's Avatar
416 stroker in a 2010 SS
LSA GMPP block
4.065 Manley pistons
Steel Total Seal rings gapped for nitrous
Callies rods
Scat crank
LSA ported heads by Brett @ Landspeed
Ferrea valves, BTR springs
10.1:1 compression
Holley Hi-ram port matched by Brett as well
Tick 238/255 cam for nitrous/F1C (eventually)
Cloyes billet gears/Z-chain, Melling oil pump
GZ Motorsports vacuum pump
EWP
Nitrous Outlet 102mm 2-stage plate, setup for dry
Old Aug 29, 2014 | 03:09 PM
  #50
trevmust's Avatar
oh, the intake valves in the lingenfelter heads are hollow, but the exhaust ones are made out of the special material or whatever? to replace the weak stock ones i think it is...
Old Aug 31, 2014 | 12:12 PM
  #51
Jimbo'sZO6's Avatar
LME built shortblock: K1 Crank and rods, Wiseco slugs, AFR big bore 225's ported by Pete at V-Max. Fast 90 and LS7 90mm TB also done by Pete.
Comp XE-R custom grind cam, 248/254, .615"/.648 on a 112+2 LSA. 11.87 scr. Made 543/493 on a dynojet on 91 octane. I did this build 5 + years ago and have around 20k miles on it and it still runs mid 10's at 130+ on a decent track if I do my part! No regrets here, would do it again in a heartbeat!
Jimbo
Old Sep 1, 2014 | 01:12 PM
  #52
trevmust's Avatar
was looking on youtube, and there was a G8 LS3(or whatever the equivalent is) with a 416 NA that made 498 or so with lingenfelter GT9 cam, so by rights we should expect that benchmark too?
Old Sep 1, 2014 | 01:48 PM
  #53
JS01's Avatar
427ci LS3 (4.070 x 4.100), 11.5:1 - prepped by HKE and myself
LS3 heads done by AirFlow Development (Dennis Wheet)
Holley Hi Ram also done by AFD, 102mm NW TB.
Cam Motion solid roller, Jesel/Morel valvetrain
Kooks 2" primary headers. (Tiny 3" collector, being changed)
Moroso vacuum pump (8-9"~ of vac, being fixed and increasing to 16"~)
Bigstuff 3 COP
Old Sep 1, 2014 | 02:50 PM
  #54
v8pwr's Avatar
Originally Posted by JS01
Pump gas street motor that I'm finishing up for my Formula:
427ci LS3 Block (4.070 x 4.100). Done by HKE and myself.
K1 Crank, Eagle H Beams, Wiseco shelf pistons with domes turned down for 11.5:1 compression.
AirFlow Development Trinity 3.3 CSA LS3 heads.
Holley Hi Ram ported by AFD to match the heads.
Cam Motion 25x/26x .756"/.747" solid roller
Morel 5425 Ultra Pro .842" Lifters
PAC 1238X springs, Jesel 1.8 Pro series solid body rockers, 7/16" Manton pushrods
Moroso 3 vane vacuum pump setup.
Bigstuff 3 COP w/ external reluctor
All the valvetrain design/finessing has been done by Erik Koenig (HKE) and myself. Will post pics soon. It's pretty much finished.
I personally never would have ran a LS3 based head on one of my own builds but Dennis @ AFD is a good friend of mine and finally convinced me to try and set of his LOL. Pretty cool to be able to do a build like this with a mostly stock appearing engine setup (besides the intake manifold of course).
This is an awesome build. I will follow to see results.
Old Sep 2, 2014 | 06:16 AM
  #55
LS3 Stroker's Avatar
416 Stroker...Build by Redline Motorsports in Pompano Beach, Florida
LSx 102 intake, big lid for Ram Air, 42lb injectors, Trick flow 255s, Compstar rods and crank, Diamond pistons, Center Force clutch, American Racing Headers, free flowing cats through Magno flow catback.
Certain I left a lot on the table with the MagnoFlow catback!
Old Sep 3, 2014 | 07:45 PM
  #56
93v8clone's Avatar
Attachment 467360
Attachment 467361
howard is a good guy , he started out up here in n.y where i live . next time ya see him tell him john waite from new york said whats up .
Old Sep 3, 2014 | 07:48 PM
  #57
93v8clone's Avatar
oh no **** your the guy with that in the sexy *** 4th gen trans am , i talked to him about this car as im doin a 427 ls3 based in mine "camaro" dow did ya make out other day at track ?
Old Sep 3, 2014 | 10:56 PM
  #58
CamanLS1's Avatar
LSA GMPP block
Callies rods
Scat crank
10.1:1 compression
EWP
Awesome build, close to what Im planning. How does the car run on 10-0 compression when not on nitrous? I am wanting to go YSI or AGP TT later down the road, but cant afford it all in one sha-bang! Im worried that the lower 10-0 compression will make it run like a dog until then. Any insight?
Old Sep 4, 2014 | 05:57 AM
  #59
Yes he is and I'll tell him you said hello!
Old Sep 4, 2014 | 06:00 AM
  #60
I don't know if you are talking about my car. Mine is the Sunset Orange 2002 on Redline's facebook page with a video. However, I haven't taken it to the track and will not consider it until I change the 10 bolt! LOL
