Aluminum 441 build on corn
Edit: it won’t let me add pictures at the moment
Got the racetronix wiring harness ran the length of the car to the alternator
I didn’t like how using the stock evap line as the return overlapped the stock plastic line, so I’m going to cut down the factory hard line and cut the quick connect pipe to length and run some fuel injection hose
It’s always something.... found a bad fitting on my brake line from the manual master cylinder to the abs delete block
Got my shifter mounted
Shift light mounted and wired up. Let me know what you guys think of the mounting location. I wasn’t sure where I wanted it, but I think it came out ok
Elongated the stock hole for the new shifter cable
No more brake fluid leaks. Ended up buying a pre made Eaton/ aeroquip brake line
Leaving it like this for now so I can flush the fuel system and the old evap line that will now be the return
Back on the ground for now. Flush fuel system, prime with oil and startup tune and she will be ready for first startup!
Wish I could be there to listen and get me a wiff of that Ethanol.
UPDATE: car cranks over has no fuel, water or oil leaks as of right now. The car looks like it will have good oil pressure, needs new battery... the fuel pump works and I’m glad I decided to flush the old evap line which is now the return line because a bunch of garbage came out of it (check pic). Just waiting for a startup tune, ******* EFI... I might just try and find someone local who knows HP Tuners. Overall everything is good as of now.
