Help deciding on best VVT cam...
I plan on getting a Yank 3200 or 3600 stall converter and wanted to get a cam that could help me out on power. I want to keep the VVT, and was looking into the cam options offered by TSP and comp cams. Are there any other companies out there making VVT cams that I should be looking at? What are some cam recommendations that will give me a good boost in performance without loosing street-ability? I plan on getting the appropriate springs when I swap cams as well.
Thoughts?
Thanks
Can someone chime in with experience with a TSP vvt cam?
-Nick
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
that is what you will get. We also make the new LT1 cams.
