Maintenance involved going solid roller?
Old Jan 14, 2015 | 08:13 PM
  #41
csequipmentsales's Avatar
Default Not Often
Not as often as you may think. We street cruise weekly at 675 lift and check them once a month. Spraying included.
Old Jan 14, 2015 | 10:00 PM
  #42
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Is anyone opposed to the idea of having the spacer welded to the valve cover? That eliminates the extra gasket...
I'm chiming in bc I myself am very curious about going solid roller with my new Mast heads.
Old Jan 15, 2015 | 05:29 AM
  #43
stevieturbo's Avatar
I thought about doing that....but sounds like that's a recipe for warping the cover like a banana with so much welding.
Kip has some covers from SDPC for me on their way, and I also ordered some of the Proform covers. Both are relatively inexpensive in the $250 range, although I will need to adapt some brackets for the coils.
Will see what works easiest for me.
