Is there anything wrong with CTS-V Superchargers? Anyone have swap suggestions?
Why do I see these all over ebay for $600? I am curious because I have a LY6 that I am rebuilding but am concerned about the factory compression ratio for my power goal. I don't have the money to change out the pistons or stroke it and don't really want to cut .030" off the heads. I don't have a camshaft or intake yet (was planning on running the LS3 or L76 intake). What do you guys think about putting one of these on my 6.0L with the 823 heads? I am planning on having texas speed spec one of their dual spring cam kits for it.
What am I missing with these? Would they be good for 500-600hp? I tried doing some looking around if people are having issues with these or any specs from them but did not turn anything up. Going to keep looking. Figured if I can get a factory pull off unit all I really need is a cable 4 bolt throttle body and some injectors and also figure out the belt alignment. Not sure if it will work with my LY6 accessories or if I have to invest in different accessories.
Thanks!!
Shane
Thanks!!
Shane
I think a fair number of these are take-offs from the recall for isolator noise. GM's recall repair replaces the entire supercharger, where a solid isolator can be purchased for $50-$100.
