ERL 454 Build for Torque?
Almost identical set-up except for heads/cam, with different results doesn't always mean the head work on one system was better than the other system (yes, I know power is primarily determined by the capabilities of the heads).
It's very possible that your bigger cam was too much for the system (compression ratio of your engine). The resulting DCR between the two engines may be 'more telling' to final power output than the difference in the quality of the head work.
Jus' sayin'.....
KW
Jus' sayin'.....
KW
My word of advice is to take your time and don't rush the decision making process...make sure you get exactly what you want!
I just finished the short block a few weeks ago:
I am targeting high HP for road racing but I would just look at what Briou did for any needed motivation. That motor will be a blast to drive.
I have spoken to a number of porters and head manufacturers and Ed Curtis at FlowTech is likely where I'll be doing my business (Mast 305cc).
The PRC 285cc option would be awesome but I am going solid roller and they don't support that quite as well.
Following along!
Following along!
Following along!
Both flotech and advanced induction are good choices
.Interested to see what you come up with.
David
David
