ERL 427 SuperDeck Build (All Motor)
#122
Wow. Now drive it down to the shop Tony uses to dyno. LOL. Westtech isn't it?
How does it feel on the street? Cam specs?
Cam is pretty conservative for the motor. If we were going for peak power it could have been quite a bit bigger.
239/248 .623/.612 113+1
#125
Originally Posted by carbuff
That is an amazing torque curve! You will enjoy that on the road course. Congrats on a great project!
Originally Posted by 98_WS6_M6
Great results. Very well built engine!!!
#126
From: Coast of San Mateo County Between Pacifica & HMB
Wow! Amazing Results Travis, Great Job!
That torque curve Is Insane! It's like the
Power overwhelmed the Dyno, never seen
A 2 second power pull LOL!
Remember I predicted 565+ RWHP, would like to
See this on a DynoJet for comparison if you ever
Get the chance. I still think 3:42s are your best
Gear for all that Torque with less then 305+
rear section width.
Congrats again on a Outstanding Build & Result!
ENJOY!
rear section width.
ENJOY!
#127
Travis,
Good job
there are so many components that have to work together under harsh conditions simultaneously... your persistance and diligence in chasing down the problems have paid off.
Good job
Good job
Good job
#128
rear section width.
ENJOY!
rear section width.
ENJOY!
I've got the log from the run off to PatG to see what we can do with the tune. This pull was on crappy California 91 pump gas and I had zero knock. I can only imagine what we might hit on some good 93 octane.
Originally Posted by joecar
Travis,
Good job
Good job
Good job
Good job
#129
congrats! Killer numbers for such a mild cam
Take it to the drag strip before you change out the gears. I'm curious what MPH it achieves.
That will be fun on the road course for sure! I can't wait to see what my 441ci setup makes. Ordering a cam from Kip next week.
#130
Assuming your building another strip motor but don't recall for sure. Build thread? Thanks.
#132
Originally Posted by D9HP
Wow!
Found another graph of your torque curve:
Tony and I discussed this build a lot and I asked him for a swag on final numbers at the flywheel before I had got it back in the car. He thought 670 fwhp was about right. Guess what we are right there and he thinks with a longer pull on another dyno we'd see peak hp go up more. How does a guy do that on a build combo he has never done before?! Man the knowledge floating around in his head is insane.
#133
#134
So did another dyno pull yesterday at Street Machine and Musclecar Nationals. Can't say I am disappointed. We all know dynos are are different and lots can affect readout. Well this one obviously had some issues cause torque was a flat line across the pill for every car on it. Horsepower sure seemed low as well and I say this not only because I pulled a lower number but some others who previously made pulls on the same dyno (different day) had much lower numbers (boosted Camaro pulled 100rwhp lower).
So anyhow, all things considered. I walked away being the 3rd highest pull of the day (525 rwhp) behind two boosted cars. What makes it really good is I out-pulled several boosted cars (a couple ZL1s with intake, headers, tune and a couple others as well). Best part is nobody gave the car a second look while it sat in the dyno line. It's just another stock 5th gen with some nice custom rally stripes painted on it. Then I started it and pulled on the dyno and the crowd gathered. Made the pulls and jaws were on the deck. Pulled off the dyno thru the crowd and people were "awesome and it looks like a stock Camaro. Even has the stock wheels." Heh heh.
Figured out I've got to rethink the vacuum pump. Blew the cleanside separator out of the valve cover on the last pull. So video attached. Enjoy.
#137
Originally Posted by blk00ss
Wtf kind of dyno pull was that. Never seen anyone do it like that.
Next dyno pull will probably be with Tony up at RPM unless I get in on a cheap dyno day down here somewhere.
I am really liking the car. Dyno pulls are just for fun. When I get some suitable track tires on it then we will see just how strong it is where it matters.
Fun story. Coming back from the event last nigh I was about three blocks from the house at a light when a new AMG pulled up next to me. Didn't think anything of it. Was going to get on it a little cause I needed his lane. Well the fckr holeshot me so I got on it. 1st? Yeah it's worthless. 2nd? Same story different gear. 3rd? Screw it you've already humiliated yourself. Totally going to have to rethink running a 285 square setup. No way that is enough tire on this thing!
#138
Like I said, not sure what was going on there and the numbers were whacked but since it was the same for everyone I felt the comparison was fare for pulls that day.
#139
Great results. Bad *** car man. Sounds like it's a lot a fun too.
Fatter stickier tires are going to be a must. I ran a 315 NT05R and it was pretty good. Still could break loose in all gears but it was a more controlled tore spin lol. Do you have all good suspension in the rear too?
Aaron
Aaron
#140
I know you don't want to run drag radials, but it's going to need them. Even going with like a 335 hard tire it's gonna still blow them off.
No this is now a road track car. Now thinking I'll need to move to an 11" rear wheel so I can jump to a 315. On a road course with some heat in the tires I'll be able to roll into the throttle a little more on corner exit. I just see there is no way a 285 is going to make it. Also need to gear down. 4:10s were fun on the old motor but this one is way too much for needing that kind of gear.
