arp main instillation
Old Jun 4, 2015 | 10:15 PM
cr250r's Avatar
Default arp main instillation
Hi guys have A 5.3l aluminum block it was line honed balenced rotating assy forged piston rods my question is with the main caps installed are the inners studs supposed to show thread? My #5 cap does but the rest do not i used arp lube on all studs into the block an outside on washers an bottom of nuts as description in my books say
Old Jun 4, 2015 | 10:32 PM
KCS's Avatar
KCS
Moderator
No, that doesn't look right.
Old Jun 4, 2015 | 10:37 PM
cr250r's Avatar
Should i un torque them and use an allen key to seat them in the block further?
Old Jun 4, 2015 | 10:42 PM
DietCoke's Avatar
wrong studs.
Why would you lube the stud on the block side? I'm so confused about what you're doing. Have you ever done this before? (I'm guessing no)
Everything should be bottomed out in the block before nuts go on - but the block should have been line honed AFTER the arp studs were added, not before - and the machine shop would (should) have known if they were the wrong studs. Did you have it honed on factory studs?
Old Jun 4, 2015 | 10:46 PM
cr250r's Avatar
What do you mean wrong studs?
Old Jun 4, 2015 | 10:47 PM
cr250r's Avatar
No i have not i rebuild turbine engines for a living
Old Jun 4, 2015 | 10:52 PM
DietCoke's Avatar
They should (all) bottom out in the block and be flush in the middle. If they don't, they are the wrong studs. The line hone should be done after studs are added - not before, since it will change the shape of the cap. If the crank spins freely, you're probably good to go - but it won't be correct and will be out of round. Loosen all your nuts and tighten the studs to the block (no torque on them, however), then retorque the nuts. For future reference dont lube studs on the block side, you only lube a bolt - because you're keeping it from binding while it torques. A stud is already bottomed out before a clamping load is applied - thus you only lube the nut side.
Old Jun 4, 2015 | 10:59 PM
cr250r's Avatar
The line hone was done with the studs hence why the block was honed or the journal would probably be out of round, i will loosen them in the morning and bottom them out and go through the torque procedure again. crank spun smoothly when it was torqued down
Old Jun 4, 2015 | 11:44 PM
cr250r's Avatar
Had to know if i had the wrong kit went back to my storage made sure the studs were seated so im pretty confident i dont have the correct kit
Old Jun 5, 2015 | 08:10 AM
KCS's Avatar
KCS
Moderator
You may just need to switch them around. The inner studs are different than the outer studs.
Old Jun 5, 2015 | 03:31 PM
cr250r's Avatar
That's exactly what it was however the outers were so tight in the threads the allen key heads got stripped i had to remove all main caps and tighten the nut till it pretty much bound up on the stud the turn left and it would come out i believe i over stretched the studs when doing this so i will be buying a new set this pay day
Old Jun 5, 2015 | 06:28 PM
KCS's Avatar
KCS
Moderator
Happy to hear you got it solved.
Old Jun 5, 2015 | 08:47 PM
cr250r's Avatar
Ya i gotta stop burning the midnight oil in a low light storage unit. I used a stock main bolt to clean the entrance to the threads on 1or 2 holes the rest were fine hopefully next week ill have the crank torqued and be doing PR and trunion upgrade this month
Old Jun 5, 2015 | 11:04 PM
DietCoke's Avatar
I'm local if you ever need hand. We just moved to the area, i'm probably 3-4 minutes from ogden gate just off post. Been there, done that. Waiting for my exocet chassis to be finished this month or early next to get that thing put together
Old Jun 6, 2015 | 09:15 PM
cr250r's Avatar
Whats your #? I live on post barracks
