Cam bearing clearance
I just installed a set of durabond chp-23 cam bearings in an ls2 block and I am getting anywhere from .0036 to.0055 clearance measured with bore gauge. I called the local speed shop and they told me to feel glad! He says most guys have problems with them being to tight. The specs I found call for .0009 to .0038. I feel what I have is a little to much? I want to get this right because I have been chasing valve train noise issuses.
The front and rear bearings are both at .005. You don't think that will cause pressure issues? I tore back into this engine after only 2000 miles after rebuild because of lifter noise on drivers side only when warm. The machine shop initially installed a set of clevite cam bearings that had up to .006 clearance. On a side note, I am going to tighten up the clearances on the bottom end. I currently have .003 on rods and .0025 on mains. I am going to shoot for .002 across the board.
Moderator
I am also using the Dura-Bond [Teflon coated] and we are shooting for .002-.0025" on the cam bearing's on our big bore 400ci engine, the same as we run on the mains and big-end's on all our Ls7 road racing engines using coated bearing's. In the Ls7 the mains receive the oil first and they are the more critical of the two, least IMO. We run 60lbs hot using a 3 stage Dailey dry sump pump and pan, and never less than a 20-50 multigrade oil.
Cheers,
Mark.
