install cam bearings with crank,rods,pistons already in?
I'm pretty sure you can not, unless there is a new way.
The way I have always done it, you have to put the bearing on the tool right in front of the
cam journal bore, you can not get the middle bearings through the outer bearing holes,
so you have to use the space where the crank sets to do that. clear as mud?
anybody have a different way?
