Milder cam for LS3 based 416?
Old Aug 9, 2015 | 07:06 PM
dbs1's Avatar
Default Milder cam for LS3 based 416?
I've had this 416 in an 02 Camaro and now an 04 Z06. Used for rr and around town as well as a few 1/2 mile events. Engine overheated in traffic and started popping and the shop thinks it had blown a head gasket.
I'm at the point that I no longer have the budget for racing and the eventual engine issues and considering just selling the car once it's repaired or, putting a milder can in it and start using it as a backup dd.
Current cam makes around 620chp and could use a little better street manners with less off idle bucking and not such a pronounced idle and a little better mpg. What would be a milder cam to accomplish this? I don't have all the cam specs but I was told this has over .650 lift. Thx!
Old Aug 9, 2015 | 10:03 PM
A.R. Shale Targa's Avatar
a buddy of mine love how docile his Texas Speed 231/237 cam is in his PRC headed 416
Old Aug 10, 2015 | 01:28 AM
kinglt-1's Avatar
TSP recommended their 233/239 for a mild street setup when I inquired about a 418 LS3 build from them.
Old Aug 10, 2015 | 01:44 AM
drew408's Avatar
I run a 235/247 .62x/.62x 114+2 cam in my 408 w/ ls3 heads and it drives really well....it's an automatic. I'd say besides the sound and more power everywhere,it behaves like stock until you stick your foot into it.
It makes 620hp/551tq on an engine dyno.
Old Aug 10, 2015 | 10:02 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
What are the specs of the camshaft currently being run? Also, what heads are you running?
Old Aug 11, 2015 | 12:45 AM
dbs1's Avatar
I do not know the cam specs. I believe the builder said it had 670 lift and it is still making power past 7000 rpm. Heads are GM cnc ls3.
Old Aug 11, 2015 | 09:32 AM
I would like to get the specs of the cam before recommending something else to you, but our 231/236 should be fairly mild in a 416cid and produce a good amount of low end and mid range torque while still offering a noticeable idle.
Old Aug 11, 2015 | 02:02 PM
*LSX RACING*'s Avatar
As I've said this for the million time call and have a custom cam made specifically made for your build as you are going by hear say or someone's own build specification. Tick or Cam Motion. Don't forget Pat G.
Old Aug 11, 2015 | 04:56 PM
With the huge amount of R&D put into our shelf stocking cams these days, there really isn't a need for "custom grind" cams. I could bet we have a shelf stocking cam for 99% of the applications we run into. In the rare instance we need a custom grind cam, it's usually something we have used before and had success with. At the end of the day, if we spec the cam correctly to the application, a "custom grind" cam would not make any more than 5-10 horse more.
Old Aug 11, 2015 | 05:15 PM
With all due respect I would not want a cam every Joe has. Also the price is generally the same as a off the self cam. With any of the cam guys listed. You can have your cam your way. Not just one sitting on a shelf with specs for a general build. He can have 1 built tailored to his build. Don't let 10 post fool you. Some may know Who I am. Nothing against you guys at Texas Speed. But Y buy a cam that has been sitting on a shelf and I can get one custom made for my application at no extra expense. Food 4 Thought.
Old Aug 12, 2015 | 11:06 AM
For what it's worth, those cams sitting on our shelf have been proven performers for 10+ years. Not saying there isn't a need for a custom grind cam. Some applications do require custom specs, but for 99% of builds, one of our off the shelf cams will fit the bill.
Old Aug 12, 2015 | 01:07 PM
I'm with you but with his build why not get one made and no need for speculation with the problems He's had. BTW how much is a shelf cam. $399.00 for a custom cam. Made 2 his liking. I'm with you. Do you guys make cams or out source cams?
I know your tying to make a sale but you can not beat the names listed for a cam.
Nothing but love for Jason and you guys over there but shelf cams have played out.
Old Aug 12, 2015 | 01:16 PM
We sell all Non-DOD/VVT cams for $399.99, custom or shelf stocking, and we will certainly grind him a custom cam if he wants it but we have used the 231/236 in a 416/418 motors before and they work great!
Old Aug 12, 2015 | 01:29 PM
Yea he's looking for something very kind on parts. I know how he feels about keep spending cash on something that will never pay him back in cash but lots of fun. But when things start breaking and you keep chasing your tail time to tone it down. I hope they finish my stuff this week. $1200 on springs and valves and this is only a street engine. Had to get Comp Cams 7/16 trunion kit for bigger studs #1299121 not for sale to the public. BTW. Saved over 1000 by not running shaft mounted rockers. If I went that route I would have around 4500 invested in a Ls3 head.
Old Aug 12, 2015 | 01:34 PM
I sometimes think about selling all of it. Naw I would have nothing to do in my spare time.
Old Aug 12, 2015 | 01:46 PM
drew408's Avatar
Sounds like he over cammed it from the beginning.
Granted mine isn't an off the shelf grind but it is considered a large cam. Mine drives stock.....
Old Aug 13, 2015 | 08:02 AM
KCS's Avatar
KCS
Moderator
Yes, some of us know who you are...
In TSP's defense, custom cams are based off of one persons experience or opinions. They don't always work out though. Shelf cams are normally tested with some R&D behind them and are often times proven for a given combo.
I'd expect someone asking for a "milder cam" would probably be just fine with a shelf cam so long as the street manners are adequate.
Old Aug 13, 2015 | 10:27 AM
Quick question? I keep seeing guys with 13:1 or 12:5 comp. on pump gas. I understand running a larger cam helps bleed off cylinder pressure. But with Temps. around 100-110 here in the city. How is it possible to ensure that it doesn't go BOOM. In traffic or while running things like A/c. Was speaking with a guy about a week ago who has 12:8 Comp in a C6 zo6 on 93 oct. Sounds good in theory and I'm sure some have done it. I asked did he have a meth kit to lower temps. Reply was good cam and a good tune.
Old Aug 13, 2015 | 11:12 AM
03EBZ06's Avatar
you just made me spew my coffee out. do you think that post count gives credentials?
Which cam vendor's veil are you hiding behind?
Old Aug 13, 2015 | 11:31 AM
Nope but me spending time and money counts for something. No cam vendor mask. Just my thoughts on buying a cam. Hope you did stain your clothes. Theres nothing wrong with a off the shelf cam if that's What You like. I like things tailor made when the price is the same.
example:
You go to purchase a new car.
Car A has no options the list are set in stone.
Car B has unlimited options.
Both are priced the same. Which car do you choose?
Theres nothing wrong with car A but I would take car B. Same thing goes with a shelf cam or a custom cam.
