Tfs 255 heads what size push rod?
Old Sep 28, 2015 | 07:40 PM
loosews6's Avatar
Default Tfs 255 heads what size push rod?
Trying to see what size push rods I need for my 408 nitrous motor with ls3 trick flow 255s with Morel 5315 lifters with stock ls3 rocker with t-upgrade....
Old Sep 28, 2015 | 10:41 PM
slowsol95's Avatar
You have to measure for length. If they will fit go with a 3/8 diameter pushrod all the way.
Old Sep 28, 2015 | 11:12 PM
tadams72's Avatar
3/8 clear no problem but length has got to be measured to get it right.
Old Sep 29, 2015 | 06:36 AM
joyridin''s Avatar
Their web site says the guideplates are for 5/16" pushrods.
Old Sep 29, 2015 | 07:43 AM
KCS's Avatar
KCS
Moderator
You don't use guide plates with stock rockers.
Old Sep 29, 2015 | 03:27 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
It takes measuring to do correctly. Basecircle, head gaskets, block milling etc all add to the measurement.
Also keep in mind the lobe profile needs to be conservative to keep control of the steel valves in that cylinder head. The 2.165" valve in it weights something like 113 grams! That's the main reason the PRC LS3 aftermarket castings feature hollow stem valves.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Sep 29, 2015 | 06:03 PM
joyridin''s Avatar
What does that matter?
Old Sep 29, 2015 | 09:36 PM
KCS's Avatar
KCS
Moderator
You mentioned guide plates.
Since he plans to use stock rockers, guideplates wouldn't be used.
