Cam info for Kip...
The shorter runners are supposed to build additional HP while moving power curve to the right. I wonder if the power moves right (peaks or hold power closer to 7K RPMS) or if the power still peaks right around 6500 RPMs....talking about natural aspirated setups, here......
KW
Update: After much discussion and several shops looking at the car, no one could figure out the problem, so we are going to try the following:
1. replace the cam. primary reason is the cam lift is too close to coil bind and I don't know for sure if its a problem.
2. If test 1 fails, engine removal to inspect both the heads and reluctor wheel.
What a pain in the A.
I have run them as close as .045" with no issues on some really high RPM high power engines.
IIRC your set-up is in the .050-.060 range which is perfectly fine and honestly is not going to cause the issues that you're having.
According to their chart, and interesting is that they state no more than 0.720" lift and coil bind at 1.18". I'm installed at 2.0". Thats 0.820" to coil bind. At 0.045" clearance to coil bind, that allows a max lift of 0.775". In theory should be good since cam is 0.748", with a theoretical 0.070" from bind.
I wonder why they recommend these springs at a max lift of 0.720".
In any case, I can not pull the engine until I've tested the valvetrain components, ie cam timing chain position, pull the cam and inspect for damage, etc. Also, not sure about the fact that the PR are 0.001 to 0.002" from the back of the rocker at high lift and demons exist there while running.
I do appreciate your help over the duration dealing w/this and like I said, I thought the specs you chose were spot on.
I have seen springs in the past that are rated at a lift that is much lower than what the actual coil bind height and installed height will allow. I don't know why they do that, but I've always felt comfortable in doing a little math to determine what can actually be utilized and not just go by the max lift rating.
That said, it's always a good idea to check the actual coil bind of your springs if possible, or having your engine builder check them himself.
I'll help you in any way that I possibly can Paul. I appreciate your kind words as always.
http://s410.photobucket.com/user/boo...pvqer.jpg.html
Reason: Unknown, but believed that engine builder reused head gasket during an on-and-off of the head after a few hours of running.
Engine to be disassembled, magnafluxed for cracks, cleaned, replace all bearings, hopefully the custom Wiseco pistons survived.
Before it goes back in the car, next few weeks hopefully, we have three cams that are going to get tested on the same day on the same engine dyno. This is not about Dyno Racing, just a relative comparison of cams.
We are going to compare and YOU will get to see dyno graphs of:
Comp Cams SR:
261/270-112+4, 0.734/0.737
268/280-114+0, 0.711, 0.711 *NEW CAM NOT TESTED*
Cam Motion LLSR:
259/270-114+4, 0.748, 0.748
Results should be interesting.
We are going to compare and YOU will get to see dyno graphs......
!KW
Expected/Current Diagnosis: Engine guy could not spot any specific problems. We are still going to magnaflux the engine block, but he suspected the head gaskets were used twice. He was suspect when he found head gasket glue on them. Rant: A guy builds an engine worth thousands of dollars and tells you to use the proper gasket. WTF would someone do this. F LS engine builders.
Camshaft: Cam Motions Cam is exactly what he said it was 259@0.050 and degreed in as 114 LSA at 110 LC.
TFS245 Heads: Interesting, the guy analyzing the engine did not think the heads were the right heads for an LS3 bore. So, expect these heads to be for sale along w/Crower Shaft mounts and 3/8" pushrods.
I have new engine plans underway to include 416 LS3 and looking at
MAST 265cc and LS9 LS3 GM 276cc CNC heads. The cam test is still happening.
My *new engine builder was the guy that was going to test the cams and we are still going to do that. He thinks something like the COPO cam would be a lot better. Unlike most know it alls, this guy is willing to put his money in place of mouth. He said if his cam does not beat all three of mine, I don't pay for his.
We are moving fast on this project!! No worries.
About the heads though ( same ones I spent my money on for this motor) not sure I'd get rid of them yet. Something wasnt right with this build from the start. I can see how you would want to start over with a fresh start but thats a lot of money to be out.
