help please big ci/ high compression breaking up *UPDATE*
$100 a case is not bad I have a parts house a hour down the road I get it from. Nothing on an engine like this is cheap. Mine got sold off because I was tired of spending money on the car every week.
Tim
Grounds sound like a reasonable thought as they are the root of most mystery issues that start after things have ran well.
You're running e85 with a 60# injector? I'd think that you were running out of fuel especially at 95% duty cycle. I'd also change the wires to at least 8mm and check grounds. How is the motor bolted into the car, motor plate of mounts? If it's mounts, then the motor make be pulling a ground lose when it torques over under load.
Btw oil won't make a difference or spark plugs imho
I don't think the plug is the issue. But, I would lean toward electrical before fueling issue, even though you seem to be pushing it a bit at 95%DC on 60lb injectors.
Good luck with the diagnosis. Let us know what you find out.
I see what i thought it was as read true the posts been confirmed in statement above, in my opinion though you said the fuel pressure doesn't drop your -6 fuel lines are running short of your fuel delivery requirements.
The fact that it try to catch on is the ages long hint on fuel shortage half way or later down the track.
Your Walbro 450 lph should be adequate with a full -8 fuel line and aftermarket fuel rails are a necessity sense oem have a step down to -6.
Though there's pressure at the line the injectors are not seen it at the time engine is braking up.
If that doesn't fix it then you must use an external fuel pump and a -10 feed line at list 18 inches long before the pump to avoid cabitation.
Please let us know how it went thanks, David.
For a while my car would cut off at 7000rpm on the track and at 7400 on the dyno.
It was as if I shut the key off and turned it back on.
I changed plugs, wires, coils, added extra grounds. Confirmed power leads.
I never found the "smoking gun" of the problem. It went away when I installed a 16v battery for testing. I swapped my regular battery back in and the problem came back.
I ended up getting a new battery and alternator and the problem hasn't come back yet.
