help please big ci/ high compression breaking up *UPDATE*
Last edited by 01 blue bullitt; Dec 6, 2015 at 01:51 PM. Reason: issue changed wasn't spark
Will it free rev
What are the specs of the engine.
Ls3 block 447 ci stroker trickflow 245's hand ported by brett land, fast 102 port matched, morel link bars, 263/271 cam, 14:1 compression, e85, 1 7/8 arh, 3 inch y pipe to 4" merge dumped, 60lb injectors which at gm fuel pressure they're 73.3# but data log says 95% duty cycle walbro 450 pump
My car with the 418 would blow the dual 3 off the car. 3.5 on mine.
-6 is too small with e85 and that much power.
Tim
ERL has not impressed me with the quality of work lately. Lots of errors and not taking responsibility for them.
Erl is not aware of the lifters you are using.
My 454 made power well past 7700
Tim
Dyno is a tool I take it with a grain of salt. It does not simulate going down the race track. That was the first time I had been on the dyno in 10 years. Didn't learn anything other that it makes 590 from 6400 to 7700.
Tim
