help please big ci/ high compression breaking up *UPDATE*
I have an XSPower race battery now. But, I don't know if the red top was a cause or not.
I do know that when I installed a 16v battery and disconnected the alternator, I made two passes with no issues. I reinstalled my optima and hooked up the alternator and the problem came back. Put the 16v back in and the problem went away again.
I made 6 passes that night trying different things to diagnose the problem and the only one that worked was the 16v battery.
I hope you get it figured out quickly. Electrical gremlins can drive you crazy.
It would get to 7000 rpm, and the engine would act like it hit a limiter, but shut off.
The data logger would shut off and come back on. The engine would come right back on, but all the gauges would act like I shut the key off and turned it back on. Full sweep of all the gauges.
Maybe try a different battery?
I like to 2 big guage earths of opposite ends, so back of cyl head, then at front of engine
I'd go over entire loom from battery to engine as well. Idle car and jiggle connections
Just for reference I had a problem with a intermittent break up/miss under load. After looking things over I also thought of the balancer as the culprit. Put a new ati unit on & no change. It actually turned out to be a broken valve spring. Keep on man. You'll figure it out.
