Resleeve an iron LSX.....highest compression N/A...??
Old Oct 24, 2015 | 03:11 PM
LS6427's Avatar
Default Resleeve an iron LSX.....highest compression N/A...??
Bore the sleeves to 4.250"
Stroke it to 4.125"
468ci.
How much compression could you run N/A with 6-bolt heads and full time RACE GAS or E85?
Old Oct 24, 2015 | 09:38 PM
Strokedcamaroz28's Avatar
im running just about 15:1 on a sleeved aluminum block.... so should be able to go more than that
Old Oct 24, 2015 | 10:12 PM
Zmg00camaross's Avatar
Was going to say a bunch! 15.1+
Old Oct 25, 2015 | 01:50 AM
DietCoke's Avatar
I ran 15 on an al block with e85. Could probably get away with more, but to what end? At some point it limits the timing you can throw at it
Old Oct 25, 2015 | 07:06 PM
LS6427's Avatar
I ask because me and a friend want to build something crazy. N/A....raw power. Race gas or E85......max effort.
If we go say 16:1 cr.....can we still spray it with nitrous? If so, how much?
Old Oct 25, 2015 | 09:31 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
I did not think one could/should bore the LSX Iron block beyond 4.20"
Especially with power adders.
Old Oct 25, 2015 | 10:39 PM
CAMSTER's Avatar
I have run 13 to 1 on E85 and is a delight running 14.1 to 1 at present on E85 and like it but for street purpose 13.5 would be my choice if I was to do it again though this ls3 is quite a beast.
Old Oct 26, 2015 | 08:00 AM
KW Baraka's Avatar
Originally Posted by LS6427
.......If we go say 16:1 cr.....can we still spray it with nitrous? If so, how much?
I know of a guy running about 15:1 and he sprays with no apparent issue.....so that much is possible, anyway.
Xactly.....
KW
