Symptom of broken valve springs?
Old Oct 31, 2015 | 01:37 AM
mr08353's Avatar
Default Symptom of broken valve springs?
LS3 in my 2013 Camaro developed a random backfire and at the passenger front of engine a dead knock can be heard about every 5 or 6 seconds. Similar to what an A/C clutch sounds like when it's engaging. Someone with more experience than me heard it and suggested s broken spring. I took valve covers off and nothing readily noticeable. Is it possible that a broken spring would generate a random backfire and if so, wouldn't the break be noticeable? I guess the next step is to physically remove all springs for closer inspection. Any thoughts or ideas???
Old Nov 1, 2015 | 12:35 PM
farmington's Avatar
is it still under warranty?
Old Nov 1, 2015 | 12:39 PM
mr08353's Avatar
Lol. Nope. Too many HP mods. I'm on my own on this one.
Old Nov 2, 2015 | 10:21 AM
farmington's Avatar
maybe have someone crank it while you have covers off and you look and listen
Old Nov 2, 2015 | 12:27 PM
racecar's Avatar
Pull the valve covers, get a small mirror and flashlight. Look at the springs very carefully.. One could be broken close to the bottom, on the back side where it is hard to see. Just like a broken brake rotor. You always expect to see it front and center. If it is on the back side and down low, very hard to see. OR: Bent pushrod???
Old Nov 2, 2015 | 12:38 PM
mr08353's Avatar
Ouch. Lol. You would have to mention a pushrod wouldn't you? Haven't done anything to bend one of those. Easier to check those than pull all those springs off. Still tempted to let it idle w/o the valve covers on them and see if I can get a better look. Just hate to make a mess.
Old Nov 2, 2015 | 10:58 PM
racecar's Avatar
OK, Take the covers off, take the spark plugs out, crank it with the starter and listen for the noise. Use a jumper on the starter. Don't turn the key on and crank it. You would have fuel and spark coming at you.
Old Nov 3, 2015 | 09:08 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
The first thing I would do if you think it is a broken spring is get the valve cover off and visually inspect the valve springs. If you have a broken spring/s you can generally see it pretty easily.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Nov 3, 2015 | 09:21 AM
MuhThugga's Avatar
Broken valve springs are pretty easily seen. This wouldn't be the first time a lifter took a **** in a LS engine, though. If you still have a warranty on the car, I wouldn't even bother with anything other than taking it to the dealer to get fixed.
Working on cars is fun and you get to beat on your chest and all that jazz, but only a fool wouldn't use a warranty.
Old Nov 3, 2015 | 12:27 PM
mr08353's Avatar
Warranty is no good. Too many HP mods. Dealership would only laugh at me.
Old Nov 3, 2015 | 12:32 PM
mr08353's Avatar
Sure. I've done that. All the springs look good. That's why I'm confused.
Old Nov 3, 2015 | 01:00 PM
mr08353's Avatar
Good idea. Thanks. I will definitely try that.
Old Nov 4, 2015 | 02:26 PM
MuhThugga's Avatar
What kind of mods?
Old Nov 4, 2015 | 02:43 PM
mr08353's Avatar
What kind of mods?
Headers, cam, new heads & valve-train
