Rectangle port heads on a 328...
I'm thinking the l92 heads offer the best performance per dollar, but if another ls3 head would be better for a supercharged 5.3 please let me know.
Right now the plan is:
Ls2 block and pistons, genIV 4.8 crank and rods, LSA blower/accessories/cam.
But yes, I do understand performance per dollar spent. That's why I'm on an LSx forum, and not a mustang forum.
I was originally looking at the $1800 fully assembled cnc ls9 heads, but I can get the blower AND a set of l92 heads for that.
I know that there are better cams, as well. But I figure the tiny lsa cam would actually do pretty good in a tiny 5.3L engine. Easy on the valvetrain and literally designed for use with the blower I will be using. If I can ever afford to have the blower and the heads ported, then I will get a custom grind cam from Martin.
I am really curious to see what happens when you put a smaller engine under a PD blower like the LSA stuff.
The $900 l92 heads AND lsa blower just seems so much more achievable. I can daydream about badass heads and whipple superchargers and not accomplish anything...or I can "settle" for l92 heads and a lsa takeoff blower and actually drive the F'ing thing.
I like to think of it as overboring the 4.8L to a displacement of 5.3 liters. Just so happens that GM already offers a block with the "overbore" I desire. Nobody ever bitches about adding displacement.
But thank you for the article. I have read a couple of similar articles on the subject, and I'm convinced that it (the quasi-COPO 328) will be loads of fun.
KW
I haven't done the exact math yet, but I think that the lsa blower, using the same upper/lower pulleys as the 6.2L lsa, will provide a good amount of boost for the 5.3, being as how it will be feeding a full 15% less cubes.
What I couldn't wrap my head around was whether or not less displacement in a PD blower setup is really a good thing or not. If you have a twin screw type blower where compression takes place in the rotor helix, then it's probably not a big deal. In a roots blower, where the air basically compresses by "backing up" in the manifold, I suspect that a smaller engine gets into higher boost sooner and creates more heat. I dunno, I digress. I'm more of an NA guy to be honest.
I chose this combination to hopefully give an awd drivetrain a fighting chance of survival. I figured the short stroke limits torque by limiting displacement, and also delays the torque delivery/production until later in the rpms, where everything in the drivetrain will have a running start to deal with the torque. The rectangle port heads also seem to delay torque production. Rectangle port heads also have cavernous intake runners, and I figured that the large volume runners would be better with the positive displacement blower, being as how it is a volume device. And I chose the positive displacement blower to give back a little early torque production lost by the short stroke, and because positive displacement blowers seem to handicap max power. All of this is beneficial to keeping an awd drivetrain alive at the upper edges of its torque capabilities. Regardless of the short stroke and positive displacement blower, this little 328 is still going to max out whatever the astro/bravada awd system can reliably handle.
