ls3 fbo 470 whp
Dragged a grandsport that laid down 510 whp built by chucke cheese @ HHP here in houston, with some bald *** Nittos and him on ET streets. Then again, not sure if he needed a driver mod.
Just looking to see what cam I have without ripping this thing apart.
You said the tune was rough and the dyno sheet says LG so can we presume the dyno sheet is from the previous owner with the rough tune?
What is the weight and mph?
When I say the calibration file was bad, I mean that the means to achieve proper afr's and ignition timing was not the "proper" way. 12.5 AFR leaving the stock maf transfer curve is the same as 12.5 AFR with a proper dialed in maf curve. Both achieve the same fuel mix in different ways. One is right, one is wrong. Power shouldn't change too much at WOT only part throttle. Dyno sheet is from the previous tune file correct.
Thanks for the input
You seem to have a really bad attitude towards LG. If you want to complain about a personal experience, there's a specific section for that. Try to keep it technical in these sections please.
Dynos are different. If the same car could be dyno'ed on 10 different dynamometers in exactly the same conditions, it would come up with 10 different HP/TQ readings; especially if the dynamometers are different makes/models.. Even if they were all the same make and model, you'd still come up with different readings....just that they wouldn't have so much variance.
If it were my car and I knew how to tune, I'd get the tune right as best as I could.
Then.....I'd enjoy the hell outta that car.....until the tracks opened up next spring.
Then.....I'd race it over a couple or three weekends to see what it does.
And if it performs where I'd expected, I'd leave it the hell alone.
To me.....you do seem a bit too hung-up on dyno numbers....and you definitely have a perverted obsession (jus' messin' with ya
) with the g6x3 cam.....KW
