L92 370
I haven't decided on a cam yet but more than it will be a small cam. I'm thinking about sending the heads to advanced induction for some work. Is it worth it get the exhaust cnc ported being that my engine is only a 370?
What about the intake valves, is it worth it to swap out the heavier valves for the lighter valves that come with the ls3? I don't plan on revving the engine past 6500 rpm?
That would be the most I would do. Work the exhaust runner and keep the intake runners as is with just a valve job. That's really where the bigger gains are to be had along with the polishing of the chamber. And do keep the stock valves, no need for the heavy *** ss ones unless you're doing boost.
