408 Build
Old Feb 16, 2016 | 09:52 PM
GML_WS6_RAGE's Avatar
Default 408 Build
Not sure if this is the right place to post this, but Im currently tying to get my build going. I have an LQ9 i plan on stroking it out to 408. I have so far LS3 heads, fast 102 intake. Just have general questions on what I can reuse from my LS1. This is going into a 99 trans am, so do i need LS3 headers too or no? I have not gotten a cam, throttle body, push rods. Just need some opinions or if you had experience with this build. Any help would be awesome. Thanks in advance
Old Feb 16, 2016 | 10:02 PM
xdanny510x's Avatar
U can use ur ls1 headers ... ur gonna need the 102 tb.. oil pan should be re usable.. u might need a ls3 water pump depending if u have clearence ... might rub on tb.. the push rods depend on ur cam selection and ur heads.. u might wanna check with a sponsor like martin smallwood eps, or vengeance.. even tsp..
Old Feb 16, 2016 | 10:03 PM
xdanny510x's Avatar
Holy **** i see ur a fellow member from hayward.. nice lol
Old Feb 16, 2016 | 10:34 PM
Yeah I'm going to talk to a sponsor about the cam. Thanks for the input. I might run nitrous too not sure when. And yes i am haha
Old Feb 22, 2016 | 12:42 PM
Do I still use the ls1 coils or should I use different ones?
Old Feb 22, 2016 | 01:59 PM
Mavn's Avatar
"I MAID THEESE"
Ls1 Coils are fine
Old Feb 26, 2016 | 07:45 PM
xdanny510x's Avatar
what kind of rotating Assembly u goingwith
Old Feb 27, 2016 | 08:01 AM
NIKDSC5's Avatar
In for results. I like seeing what an Ls3 top end on a 408 will do.
Are you going to have the heads ported? I'd send them to AI or TEA
Please use roller rockers.
What compression ratio?
You should be fine with Ls1 water pump on an LQ4.
Old Mar 5, 2016 | 08:20 PM
K1 Crank, Lunati rods, wiseco pistons.
Heads are stock i think i might keep them like that since porting is going to cost me a chunk that i don't think ill have in time haha. I was going to ask too if the stock ls3 rockers would still be good to use or go a different route. Im shooting for 11:1 CR ill be on pump gas tho
Old Mar 5, 2016 | 10:09 PM
xdanny510x's Avatar
As long as ur rockers have the truniom upgrade rockers...u shud be fine on that comp. I was on 11:8:1.. who doin ur build?
Old Mar 6, 2016 | 12:36 AM
that was my next question haha about the trunion upgrade.
i need to find some one here in the east bay to bore it and install the bottom end. any recommendations?
Old Mar 6, 2016 | 08:57 AM
snapp88's Avatar
I seen martin Smallwood I don't know if anyone has heard. He no longer works for tick performance. I am in the process of my 408 build as well. Called to get a cam specd. Called back in a few months to order it and they said he no longer works there.
Old Mar 6, 2016 | 10:20 AM
xdanny510x's Avatar
U might want to hit up synergy motorsports or csm in suisun city...or even s&s in san leandro
Old Mar 6, 2016 | 10:21 AM
xdanny510x's Avatar
Martin smallwood has his own shop now.. u can look him up and ull get his info.. he still here.. just on his own
Old Mar 6, 2016 | 02:55 PM
yeah I'm going to hit them up tomorrow see if i can get this done. did you use ls9 head gaskets? heard its the way to go with these.
Old Mar 7, 2016 | 09:42 AM
xdanny510x's Avatar
I used mls gaskets
Old Mar 7, 2016 | 11:32 AM
ARP Main Stud Kits 234-5608 these the right ones?
Old Mar 10, 2016 | 07:13 PM
xdanny510x's Avatar
I believe so.. u might wanna check with a vendor just in case
Old Mar 26, 2016 | 09:28 AM
I'm going to order the bearing so they can be here next week to take my block to bensure worked on. The lq9 I have is an 05 with the knock sensors on top. Wasn't sure which cam bearing style fits in there.
Old Mar 26, 2016 | 03:04 PM
DavidBoren's Avatar
Don't just shoot in the dark with head gaskets. After the shortblock is assembled, measure the piston in relation to the deck and get the proper headgasket for good quench. It's the right way to do it, and it's not that expensive, and there are literally no drawbacks.
Anyways, the stock rockers (with a trunion upgrade) are good for everything up .650" lift, or so. Anything under that and you should be fine with the stockers.
LS1 headers will bolt right up to the LS3 heads, no worries. If you are ever even thinking about laughing gas, you should step up to 2" primary headers now. The big cube 408 will enjoy the larger headers, as well.
