Planning my 416 build thread!
Old Mar 21, 2016 | 09:36 PM
03EBZ06's Avatar
Op, heads are constantly evolving and I have wanted to experiment with a larger intake volume for some time. That is reason I'm testing these heads. According to Mast they are some bad boys. We shall see. Btw what happened to your post ? The Mamomeister has proven stuff. Bolo and I are both testing these heads with diff intakes. Results posted soon
Old Mar 21, 2016 | 11:17 PM
uxojerry's Avatar
Check out that ls2 403 build with the new heads from dart. 700hp is pretty good with $2200 out of the box heads.
Old Mar 22, 2016 | 06:26 AM
josh4ku's Avatar
What do you mean what happend to my post?
Old Mar 22, 2016 | 06:27 AM
josh4ku's Avatar
I will have to check that out. Thanks
Old Mar 22, 2016 | 09:19 AM
03EBZ06's Avatar
ET/mph ? With that car?
Old Mar 22, 2016 | 09:11 PM
Martin Smallwood's Avatar
Originally Posted by blk00ss
Still not going to make as much power as a set of worked TFS 245's
Didn't you make 540 rwtq?
Old Mar 22, 2016 | 09:16 PM
blk00ss's Avatar
Nah. Just 535
Old Mar 22, 2016 | 10:50 PM
Close enough!
Old Mar 23, 2016 | 09:48 AM
03EBZ06's Avatar
530 rwtq on a stock zo6 cam and only 416 cid. The TFS heads tolerate a wide variety of cams. btw Martin I think your cam should come out on top but that 268 going to be interesting
