Planning my 416 build thread!
My main hang up is i can't decide which heads, there seems to be a lot of good places to buy heads these days, and who I should have spec the cam.
Mamofied fast 102
102 throttle body
60# injectors (already have)
Underdrive pulley
TEA TFS heads or Mamofied afr heads.
BTR valve springs
Stock rockers
Forged shortblock from TMS.
Custom cam. Not Sure yet. Martin Smallwood or tony Mamo
Ls7 lifters
Racetronix 255 fuel pump. (Already in the car)
1 7/8 headers, not sure for the rest. I currently have magna flow, but I'm guessing that isn't going to flow enough. Maybe just run it with a cutout.
I would love to make 600rwhp, but i know that is probably never going to happen on pump gas. 550rwhp will make me happy. I'm thinking 11:1 cr. I will be using 91 octane. There isn't any 93 pump gas available around here!
My main hang up is i can't decide which heads........Custom cam. Not Sure yet. Martin Smallwood or tony Mamo........
Read this ---->> https://ls1tech.com/forums/dynamomet...l-results.html
KW
KW
I mean....for STREETABLE power, I think many of us would pass on a cam with 38 degrees of overlap.
IJS....
KW
IJS....
KW
IJS....
KW
And it's only 33* of overlap. And I guess the 17hp more car you're referring to is the one you linked to? Well it has almost the same compression as mine. 1/4 point off. Woooooo. Oh and he had a electric water pump, RPS lightened flywheel. I had a box stock fast 92, stock water pump, 3" steel driveshaft, 295/55/15 drag radials, 9", spec stage 3 with heavy steel flywheel.... I wasn't after a dyno number. I was after track results. And it performs there.
PM or email me today....we can arrange a phone call to discuss the build.
I have helped many folks achieve exactly what your looking for. We can go over various options as well as cost and how they effect the end results.
Look forward to speaking with you
Btw I have built (and helped build) over a dozen 416's at this point and all of them with excellent results.
Regards
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Regards
Tony
