CNC cathedral or LS3
Factory LS6 intake and self modded throttle body
Buddy of mine offered me some 0821 casting heads off his 12' GS vette with less than a thousand miles in them since new. He's trying to get me to go with his LS3 intake/throttle body on my short block.
I checked and the chambers measured 4.060" so about .020" shrouding will be the case on my engine.
My pistons are at zero deck so a .040" Cometic puts my squeeze at 10.8 without milling. Down about a half point from my current heads at 62cc with the much cheaper LS2 gaskets
Thoughts on if I should stay the plan with my 3.42 geared M6 car or consider running the LS3 top on my LS2 short block and whether or not I should also change the camshaft even though I would DIY port the 821 exhaust side
I'm only shooting for around 440 rear wheel but want near stock drivability with occasional 1/4 mile blasts. Mostly cruising type driving.
Comments welcome
If it was more than just a mild street cruiser I'd say LS3s with a new cam for sure, but those heads will perform better on the street with the smaller runners and higher compression.
However, if you already have the 799 heads and don't plan on buying a new throttle body to bolt to the LS3 intake, then I would just keep what you have.
My cathedral combo will most likely need some FAST36 injectors to meet my target power level.
I'll probably end up staying the plan as my short block and heads are all together and I'm happy with all the clearances.
For me the temptation comes from the intake and TB being better and the heads having such few miles on them, practically new.
He also has his original LS3 block/rods/Pistons/rings which he pulled at around 2K
I just can't justify starting over with his stuff for eight more cubic inches.
I'm thinking you guys have convinced me that I've picked the appropriate combination for the intended usage I have for my car
Thanks again 👍
Jason
No it won't make a car less streetable with LS3 heads sure. But a car with small port high velocity heads flowing the same as some monstrous rectangular heads will drive a helluva lot better and snappier on the street.
How do you explain that?
PTV clearance is also much less on the LS3 head with it being the same 15 degree valve angle. Your cam may not be large enough to pose an issue, but you certainly won't have as much cushion in the event of an over rev or if the valve springs begin to weaken over time.
Jason
No they're not.
