budget 370 extreme abuse advice
picked up a lq4 to have some fun with, looking to build it cheap with some good power and can handle high rpms for a extended time.
gotten as far as
carb intake and msd box - makes the swap much easier
30 over
stock crank cleaned up or a ls2 unit - so far i haven't found anything saying ones is better.
ls3/l92 heads with better springs and upgraded stock rockers, otherwise untouched
now this is where i start to know enough to make bad life choices
for rods was going to use LSA rods with arp bolts, as they seem to be pretty beefy and cheap but it limits piston choices as they are 6.098. aftermarket rods open up pistion choices but adds another few hundie on the bill and are they worth it?
witch brings me to biggest thing. i have zero idea for pistons,
i know i dont want to go over 10:1 to keep it pump gas, also like to keep the set under 800. the motor is going to see a fair amount of stop start use and extended time at 6k, as high as 65 for burst. i know they will have to be coated to take the abuse, and that is all i got
gotten as far as
30 over
im limiting it to keep it on 87/89 oct, with a 180L tank, id like to keep the fuel bill in check haha
