Looking for help on cam selection
Old May 11, 2016 | 09:42 AM
M1SERY's Avatar
Default Looking for help on cam selection
So I change my heads on my 370 to the tfs 235 58 cc, 92/102 intake port matched, 1 7/8 headers and put a 239/258 112 with center line at 107 , took it to the track and it fell short of what was expected only pick up 1 mile per hour and close to the same et as before. 118 @ 11.88 with the new set up, the old set up was same short block 1 3/4 headers, 92/92 , and prc 5.3 stage 2.5, ran 117 @ 11.80 , so I thinking the cam is the suspect.
Old cam was 236/250 115 +4
Any help would be appreciated
Old May 11, 2016 | 10:22 AM
redtan's Avatar
What was the previous cam that you had in there?
Hard to imagine all those mods only picking up 1mph, something else must be up with the new setup. That thing should run much better than that.
Mavn's Avatar
"I MAID THEESE"
That exhaust is HUGE for a 370.. Bigger than I have in my 418.
Id change up the cam I have a 235/242 in my 370 ci.
Old May 11, 2016 | 10:43 AM
M1SERY's Avatar
Sry just edited it , car is 3655 lbs
Old May 11, 2016 | 11:28 AM
M1SERY's Avatar
what where your track times and power numbers for your 370
Old May 11, 2016 | 03:08 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
TOO MUCH EXHAUST SPLIT! & Narrow LSA with TFS CATHEDRAL HEADS, Even with 200 shot. 4-6* exhaust split with good flowing
Exhaust NA, 200 shot +8-12* would be PLENTY.
235/243 mostly street, 239/251 mostly strip with
TFS 235s on a 370" LSA (112-114) ADV +3-4)
with a 200 shot.
No expert just my .02
Old May 11, 2016 | 07:15 PM
M1SERY's Avatar
with a 200 shot.
Thanks , whats ur back ground, with ls stuff, you seam to have a lot of knowledge,
Texas speed has a self cam what u think, trying to get my head around this stuff , so far I'm doing a poor job, do u think this cam will make any torque,
who would cut that cam u mentioned
Attached Thumbnails Looking for help on cam selection-screenshot_20160511-190949.png
Old May 11, 2016 | 09:07 PM
I would have Kip @ Cam Motion, or Brian Tooley @ BTR
(who was at TFS when they designed the 235s) spec you
A cam. I am not an engine builder or mechanic. I have
A custom build going for my C5 Corvette. Been reading and
Studying about Engines along time 35+ years the LS for
The last 9, been to a couple Tony Mamo Dyno tests for
His builds, reading LS1Tech @ CF for 9 years also.
That 244/248 cam is Wrong! For a 370" better for a 418"
4" stroke would have very poor low end torque in your
Engine. Based on the mods in you're sig I'm guessing
This is a 90%+ Strip Car?
Again my .02 is 370" with TFS235s 235*-239* Intake duration
Normally Aspirated add 4-6* to the exhaust, with a 200 shot
Of N2O I would add 4-6* on top of that.
Lobe separation and advance would be better specced by the
Aforementioned cam experts.
Again that TSP Cam is all wrong for your combo IMHO.
Old May 17, 2016 | 12:47 AM
03EBZ06's Avatar
Wrong cam w/those heads and that intake. I have experience w/the TFS235s, 416 of course. I think you are trashing hp with the 112 and long exhaust lobe.
Look at something around 239/247-114+3 or ask Martin. He has some good cam ideas for those heads.
Old May 17, 2016 | 07:38 AM
HCI2000SS's Avatar
I agree with these guys about asking the experts. I'm positive they will come up with something much better than the one you mentioned
