Need PRO help deciding on a N/A LS7 setup!!!
Old May 30, 2016 | 01:53 AM
That_One_Person's Avatar
Originally Posted by ssbandit158
What do you mean by AI 280's
Advanced Induction 280cc ported stock castings. I'd post a link, but uh not sure they are a sponsor.
Old May 30, 2016 | 07:49 AM
KCS's Avatar
KCS
Moderator
There's a Vendor Directory tab at the top of the page so you can check when in doubt. I'm not finding them on there anymore though.
Old May 30, 2016 | 05:28 PM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks for the detailed response Tony, I appreciate the info and will definitely be giving you a call. I've already talked to ERL and they have been super helpful as well. As you said above I just want to build it right the first time. I bought the car and owned it less than 3 weeks before the motor blew, it was built by cartek in Georgia, needless to say I won't be using them ever again.
Sounds good...I think I can make this alot more manageable for you and help you achieve all your goals. The biggest questions are would you want me to build it for you or simply send you all the complimenting components for you to tackle the assembly yourself. Either way you end up with a killer optimized combination!
Hit me up this week....ring my mobile number when you have some free time and we can discuss in more detail. Afternoons and evenings are best for me....leave a message if I cant pick up the phone.....Im good at returning messages etc.
(661)714-1317
Cheers,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old May 30, 2016 | 06:38 PM
ssbandit158's Avatar
(661)714-1317
Cheers,
Tony
I would need the shortblock built at least so everything is properly align honed and all the clearances are set up properly. I'm an Aircraft mechanic by trade but obviously don't have the machining equipment to deck, cnc etc. I am capable of putting a rotating assembly together but I'd rather have the whole engine assembled by someone who does it every day, I would be very unhappy if I missed something and my motor failed. So I'll give you call and we can figure out the best plan of action. Thanks again Tony.
Old Jun 1, 2016 | 10:22 AM
NHRATA01's Avatar
Originally Posted by dr_whigham
If you're set on running LS7 heads RUN AWAY from the LS7 Fast intake. Look at what Mamo does with the MSD LS7 and how cheap it comes out.
You can make 600+ with AI 280's... You don't HAVE to go aftermarket. But if you did, I'd definitely go with MAST anything.
I'm curious, haven't been following the game closely enough for the past 3-4 years, what's the issue with the LS7 FAST? I've got an old (Mamo ported to my AFR 205s actually, done about 10 years ago) Fast 90/90 setup. Been starting to throw together a plan for an N/A big cube setup and was probably going to top it with a Fast 102.
Great thread BTW, OP please keep us updated I'm very interested in your build.
Old Jun 1, 2016 | 03:07 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Issue with the FAST102 VS MSD (LS7 application) is that a Tony
Mamo ported (MAMOFIED) MSD makes 20+ RWHP VS Tony
Ported Fast 102, due to inherent design advantages of the MSD
INTAKE ( Larger Plenum, Shorter,Straighter Shot Runners) there
May be other advantages that Tony and/or others may elaborate
Further & better than I.
Old Jun 1, 2016 | 03:28 PM
streetassasin's Avatar
Stock bottom end ls7
Mast 285's
vengeance sumbich cam
vengeance ported fast
nick williams 102
11:1 compression
Put down 600/525 in my 09z
Old Jun 1, 2016 | 03:51 PM
What are the specs on that Vengence Cam?
How does it drive?
Old Jun 1, 2016 | 06:24 PM
lowcountry's Avatar
From: Grew up in Charleston, SC live in Moncure, NC
Mast 285's
nick williams 102
11:1 compression
Is that rwhp?
Old Jun 1, 2016 | 06:39 PM
247/258 .661/.652 112+4, driveability isnt horrible but you can definitely tell it has a big cam. Yes, 600rwhp 525rwtq
Old Jun 1, 2016 | 09:46 PM
So not "Too Horrible"
Just a little horrible.
Old Jun 2, 2016 | 08:47 AM
  #32
Mast 285's
nick williams 102
11:1 compression
I see everyone talking about MAST 285 heads, why not the MAST 305's when they are the same price?
Old Jun 2, 2016 | 08:52 AM
  #33
(661)714-1317
Cheers,
Tony
How much do you think I would pick up going from my vengeance ported fast to one of your ported msd's?
Old Jun 2, 2016 | 01:11 PM
  #34
If you read through the post he say's about 20hp over a ported fast.
Old Jun 2, 2016 | 02:59 PM
  #35
Because 285 CC is already a large port for a 427" street engine, go
To 305 CC and your port velocity below 3500 RPM especially
With a mid to high 240* duration intake cam will have poor
Throttle response (not to mention bucking and surging on the street) compared to a 265 CC Intake port that can flow
400+ CFM @ .600" (enough airflow for 800+ NA FWHP) and with
A low to mid 230* intake duration, still enough for 600+ RWHP
with a ported MSD and rip your head of throttle response to go
With very good driving manners.
Old Jun 2, 2016 | 03:02 PM
  #36
LS1Tech Sponsor
Most guys are seeing 20-25 RWHP which needless to say is a really stout gain over (formerly) the best piece out there.
This thread has some results in it
http://www.corvetteforum.com/forums/...msd-gains.html
This one also...same scenario....FAST to one of my ported MSD intakes.
http://www.corvetteforum.com/forums/...-600-rwhp.html
I have these down to a science now having built some special tools/gauges to measure things as the porting work is getting done....I have done dozens already all of them with excellent results and feedback....alot more threads if you care to look on the Vette forum
-Tony
__________________
Old Jun 17, 2016 | 01:15 PM
  #37
So here's a question, ERL drysleeve block or a warhawk block? Pro's and cons to each. For the cost of the ERL drysleeve shortblock I can buy a warhawk block and callies rotating assembly and have my local shop put it together.
Old Jun 17, 2016 | 03:35 PM
  #38
KCS's Avatar
KCS
Moderator
The ERL block is going to have longer sleeves.
Old Jun 17, 2016 | 04:32 PM
  #39
slogo's Avatar
Superdeck 6-Bolt Sleeves are approx. 5.782 average all 8 cylinders.
http://www.erlperformance.com/produc...ocks-packages/
Old Jun 17, 2016 | 04:46 PM
  #40
LS1Tech Sponsor
I just cringe at the weight of a Warhawk or any really stout (heavy!) cast iron block.
Unless the goal was to make well into the four digits (where the weight isn't such a factor any more and the cast iron block improves ring seal from better structural integrity of the block), I would advise saving longer if necessary and going with a much lighter sleeved aluminum block.
Especially in a car that's more of a street car than an all out track car....weight negatively effects everything....handling, braking, ride quality etc.....its not just how much slower it may be in the quarter mile.
Just my .02....and I'm not sure what the OP is actually doing so these are just my observations/opinions in general
-Tony
__________________
