P2V clearance
Old May 18, 2016 | 08:59 AM
mr08353's Avatar
Default P2V clearance
Still building my solid roller setup and measuring P2V clearance. With .644 lift on both I/E, I was expecting between .060 and .100. Unexpectedly got .375. Where do I start first to find out what happened? It's like the valve isn't opening as much as what it needs to. Plz and Thx.
Old May 18, 2016 | 11:27 AM
anthraxmm's Avatar
How are are you checking the p2v?
Max lift has no bearing on p2v
Old May 18, 2016 | 11:28 AM
KW Baraka's Avatar
1. What are the rest of your cam specs?
2. Has the block been deck?
3. What heads are you using and have they been milled?
As it stands, you're not giving enough info.....
Originally Posted by anthraxmm
......Max lift has no bearing on p2v
I agree. But I got fought tooth and nail when I made that statement .....
In a properly spec'ed cam, lift is the least important spec as it pertains to piston/valve clearance.
KW
Old May 18, 2016 | 11:33 AM
mr08353's Avatar
Thanks for the reply.
Modeling clay method.
I understand duration has a greater impact on P2V clearance than lift, but what would explain .375 when it should be .060- .100?
Old May 18, 2016 | 11:38 AM
KW Baraka's Avatar
......I understand duration has a greater impact on P2V clearance than lift, but what would explain .375 when it should be .060- .100?
Can't say.....and won't even guess without knowing the rest of your specs.
KW
Old May 18, 2016 | 11:53 AM
mr08353's Avatar
KW
Attached pic.
Factory LS3 ported heads. 7.200 push rods.
Crower adjustable rockers.
Old May 18, 2016 | 12:02 PM
anthraxmm's Avatar
Attached pic.
What does the bottom end consist of? Pistons, head gasket etc..
Old May 18, 2016 | 12:37 PM
mr08353's Avatar
All stock.
