LS7 heads?
Planning on ordering me a 454 LSX standard deck and was thinking of running ported LS7 heads. A MAST single plane intake and accufab throttle body. Will i be fine with the GM LS7 heads or look into Brodix heads? Goal will be to make decent N/A numbers and see around a 300 shot later. Thanks.
Both stock and brodix will make good numbers. I've seen a brodix ls7 heads go over the 900hp mark na. There are porters that put a nice touch on those heads.
As far as intake I would get the CID ls7 over the Mast. More plenum volume and cheaper.
