LY5, LS1 interchangeable?
Is anything off of a 99 ls1 (intake, cam, accesories, heads) interchangeable with a LY5? did some searching and didnt find much results? i know its a 4th gen block but i want to know what ill have to do to make the swap as least painful as possible. thanks
Restricted User
Everything you mentioned is interchangeable, but you might have to drill/tap the block for the F-body alternator bracket. The iron blocks weren't drilled there from the factory, but the material is the same.
I’m getting ready to swap a gen 4 5.3 into my 2001 camaro, was wondering how the swap went for you and if you had any problems or specifics you come across. Also wondering what you did for knock sensors and valley cover. Thank you
